B20-CRV VTEC - Why it Blows.....
shiroitenshi
3,676
170
thanx 4 the info..
blown my engine last month..
now left at danau kota woksop...
but, why can't use the piggyback??
Piggyback applies what we call a lambda on the original fuel mapping.
remember the tables your tuner looks at?
XXXX| 1 | 2 | 3 | 4 | (more, but omitted)
1000 | 2.00 | 2.10 |2.50 | 3.00 |
2000 | 3.00 | 3.20 | 3.6 | 4.00
(more, but omitted)
as an example,
The RPM is the 1000,2000 value, called the RPM index,
The 1, 2, 3, 4, is the load zones (or load index), some, like the PowerFC, uses numbers, while hondata, uses actual units (it doesn't matter really) Most piggybacks just use TPS to simulate the load index, like VAFC, Neo, etc. which means a little like guessing where the computer is ACTUALLY reading the map from.
Yes, unlike what most people think, tuning is not really 100% exact science. Remember vacuum advance? Lol, that's not controllable at all, but the old fellas did it by use of springs and such, heck, they don't even care what kind of ignition it's running, as long as it made power.
You can also replace the load zones with TPS indexing on standalones, but usually that's done for running quads, because they can't have good part throttle (on/off driving) at low rpms due to lack of good MAP signal (it's doable, but well, what's the benefit of running quads with a tuning method designed for manifolds?)
That's why that's there manifold versus ITB, which is better? debate down in honda-tech, I think.
Back to topic. Well, what the piggyback does is apply 'adjustments to the map'
xxxxx| 1 | 2 | 3 | 4 | (more, but omitted)
1000 | 1% | 1% | 1.5% | 3% |
2000 | 1% | 1% | 1.5% | 3% |
(more, but omitted)
Like emanage, and unichip, they work in this method. They add adjustments to the original mapping, which is all good and fine, if the original mapping is static.
The thing is, the mapping of honda ecu's in open loop mode is not static, (for the most part, at near to full throttle it's static) it changes from time to time, courtesy of it's long term and short term fuel trim. I think powerFC does this feature the best as an example, just start and wait for it to find it's own idle during intial setup. That is a more extreme example of how it works, but even the stock honda ecu's have that feature, although not at such a high correction rate.
But it's not like piggybacks are bad, they are good for minor adjustments, esp when the original ecu mapping is suited to the engine, but just need a little tweaking.
In the B20B case, most of the ECU's used, the original mapping is for the B16A, imagine what kind of adjustments are needed for that, and what kind of fuelling changes the original honda ecu will do as time goes by.
having a static lambda (fuelling adjustment) while the stock keeps adjusting itself, it's like trying to swat a moving fly while driving a car in the rain. lol. those raindrops and the fly start to blend in.. and both are moving, so you can't really see where the actual fly is.
I'm not sure if the newer gen piggybacks start tricking the 02 into a closed loop mode yet, but if you're the curious type, if D14 on the P30/P08 ecu is connected to the piggyback, then it probably is. I think that's probably one way to get around it, but well, originally piggybacks were made to map more accurately the original mapping (cleaning up the mapping due to added mods that changed the flow of the engine, when the original cannot cope anymore)
I don't think it'll ever come to that since it's like the piggyback trying to become what it's not, but well, just thinking out loud.
Well, that's just a small aspect of tuning. Now I know why mat salleh find it so fun. :P
D-IV
262
long time then baru kena reply... haha...
Over revving too generalized lah. Or maybe just didn't bother to open up and find out what was the weak point. But nevermind.... not that i'm bothered. If built properly and tuned, it should be able to last. Human error is most of the time that blows motors...
pencalat
805
19
JB
haha... bz ar bro...
summore tgh kumpul wang mau kasi cun cun punya...
the prob now, rpm n speedo mcm biol la...
maybe distributor....
pencalat
805
19
JB
overrev?
can i know your shifting point?
stnd internal?
aiyoh...
frankly speaking... my english not good enuff..
sometime certain word that i didn't understand...
more over in matter of car issues.. i always wrong predict...
shifting point that what rpm that i shift tha gear kah??
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
aiyoh...
good answer... i learn a new thing today...
jeheyr
834
19
5,018
Ampang Jaya
community.webshots.com
aiyoh...
aisey... mine also not so good..
yeah, thats what i mean.. rpm when u changed gear..
one more.. u still using standard CRV piston?
dcloo
1,784
17
kl
as an example,
no matter what stand alone ECU/Piggyback you tuning your car running in 13.5:1 < CR with pump gas (petronas,sheel,mobil,bla bla bla) daily driving confirm your piston will melt/blow your engine
some sample picture show below using wesico 12.5:1 CR and skim head&block and around 13.5++:1 CR after 15000 KM tune with microtech LT 10s
pencalat
805
19
JB
hehe... for the moment of my pow sin chee b20b... yup i used the std CRV piston..
i've changed almost at 9k at that time maybe more... didn't rememberlah...
then... kaboom la... asap putih from front bonnet.....
conrod patah... head terangkat... 1 best part is i can see my piston...
hehehe....
Northiswara
2,589
7
hehehe....
soli to cucuk half way in but curios. :idea:
u use what head? b16a? b18cr? b20b head?
jeheyr
834
19
5,018
Ampang Jaya
hehehe....
fuhh.. with stnd p3f piston rev until 9k..
thought b20 will lost torque after 8k rpm..
is it true dcloo/hattech/shiro? - consider using stnd internal part(no jun/skunk/whateva)..
dcloo
1,784
17
kl
this happen normal where the con rod bearing was wear out and cause the jam then only the rod will broke 2 pcs cause he mention he still saw the piston, if piston was break u can't even saw a complete piston on high rev cause will hit the head and rod will crack in 1000 of pcs and if you think to rev so high always recommended change to better bearing like ACL race bearing/stock type r bearing its reduce the risk of bearing worn out in such high rpm This i have did a b20b for my customer and equip with toda C cam went to track days 5 times with P3F piston and the engine still very healthy no white smoke/silence engine condition and its just service his car every 5000 km
shiroitenshi
3,676
170
Usually head won't terangkat unless even the head bolts fail spectacularly (I think it's unlikely, there's 10 of them, and if you were cheapskate enough to REUSE them that often, I have NO COMMENTS.)
Blown engine usually means a broken rod, the rod will whack the liner and eject a chunk out of the side of the block. That's why most blown engines will always have a hole at the block. It's not the pressure that makes the hole, it's the broken rod. This is probably the most common damage I see on B16a shortblocks, which is usually traceable to the owner deciding that 9.5K rpm is a good idea on stock valvetrain, and installing an ecu without a revcut.
There's also the valve dropping part. This one is the piston has a hole, the rod may or may not break (but it will at the very least be bent beyond repair). The piston has no melted edges/VERY pitted surface that are the telltale signs of detonation.
There's also improper installation. The signs will be almost like the valve dropping, except in this case, it's the pistons hitting the valves at high rpm. Cam and stroke cycle = not enough minimum clearances. The rods stretch at high rpm, so if the valves don't touch the piston during installation, there's no guarantee that it won't at high rpm. I think the minimum clearance is quite large for high rpm engines, in the region of 3mm+, esp when they are degreeing the cam.
There's also hydrolocking, which can be due to driving over puddle and the intake sucking in quite a bit of water, this one also can break rods, and etc. Hydrolock can also be caused by leaking gaskets, though this is probably not as common.
There's others, but I'm sure others can contribute.
<a href="http://www.zerotohundred.com/newforums/features/144237-k4-gp-2007-sepang-circuit-malaysia.html"><img border="0" src="http://www.zerotohundred.com/features/k4_gp_2007/banner.jpg" width="250" height="75" alt="K4 GP Sepang Malaysia 2007"></a><br><b>K4 GP AT SEPANG CIRCUIT 2007</b><p><b>Images</b>: Mazranz<br><b>Words</b>: Mad House (Japanese Direct Translation)</p><table border="0" width="500" cellspacing="0" cellpadding="0" id="table3"><tr><td><img border="0"...
