SITC & SAFC - Self tuning ?
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
hollaa..thx 4 da reply bro..here da detail
1 myvi 1.3L
2 im using Apexi open port
3 custom exhaust system from extractor to twin-tail
hope its may help u..
thx again..:biggrin:
so, how u wanna me to help..??
u got the Neo edy, been tune by some1 else, then now u wanna tune it again by diy.>>??
EzD-K6
41
never tune it..coz i bought it from ma fren (kelisa onwer)..if can tune diy, why not...
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
then u can come to my workshop la... coz u need to install 1st.
my workshop is at Uptown PJ. Near 1 Utama Shopping Complex....
so, when u wanna come over..??
EzD-K6
41
FYI, im installed it 2 month ago but never tune..BTW can u give me ur contact or address workshop..thx bro
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
ok, here is my contact. 017-620 7538(Jin).
anythings, just call or sms me la... thanks..
Northiswara
2,589
7
jin,
ur workshop got transplant engine?
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
yup... my workshop do anything.... from welding to tires, then air-cond till yam cha & blow water.... servicing, modified & re-wiring.... with some R&D......
Northiswara
2,589
7
wah. so canggih!
do u clean injector using ultrasonic equipment (not the OSIM ultrasonic cleaner)? how much u charge?
Northiswara
2,589
7
i feel like to buy a tuffoil and pour in 1/4 into my engine to taste the smoothness of it. i had run 2000km already, another 3k km to go for oil change.
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
wah. so canggih!
nop... why..?? is that thing really need for these days..?? i dun think most of ppl will pay for it... coz not really necessary. lets the pro done it... hehehehe....
Northiswara
2,589
7
want to ask u sth.
my car resevoiur tank water drop slightly. if rev the engine then it will drop faster. at the moment it drops little by little cozs i drive normally with light foot.
i went to mechanic and he checked here and there got no leaking sign. jacked up the car and inspect for coolant greenish stain but we didnt find any. i only notice tat there are coolant greenish stain on the resevouir cap there. so does this means that my resevouir cap bocor and cause the evaporated water to release from the resevouir tank?
:adore::adore:help me sifu!
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
mayb... try 1 time with coolant then not exceed the maximum line. see how...
do the compression test as well... scared later ur coolant sneak into ur engine....
Northiswara
2,589
7
my resevouir tank is weird. the max line is actually less than half of the bottle. which means the tank will store more air than water. usually i will fill 1-2cm over the max level because the max level is quite low. if the water above max level for sure u will see the water slowly drop til max line. then stable there, but once i lent my car to my fren for 1 week then i check my water level in the resevouir tank, it reached low level. i was farking high that time! that fella is heavy footed.
if the water leak into engine that means the gasket got loss compression. so far the engine was fine. got power. i not sure which workshop got provide compression test here. i at prai, penang.
Northiswara
2,589
7
by the way u ever heard of slick50? sth like tuffoil but this one more powerful. cozs u only need to use once and the effect can tahan for 50,000km++. my fren using it once in his wira 1.5, after 2years the engine still very smooth and his car temperature remains below half of the gauge which is lower compare to stock wira. so far i see parkson got sell it. rm100-180 like that.
:_: just wan some opinion from u guys/sifu out there
which one is more faster
-a std stock evo 3 engine wif full lock LSD gear
or
-a MITSU GSR 1.8 wif MIVEC head,evo programer, TDO5 h turbine n full lock LSD gear
-need all ur guys/sifu oppnion...........:shades_smile:
