port and polish
hillies
46
wad are the the advantages and disadvantages of port and polish?
i) Carbureator Vehicle
ii) Fuel Injection
THx!~~
Northiswara
2,589
7
0-100km/h in shorter time.
naik bukit easier.
press sikit accelerator car already can fly.
easy to get wheel spin.
for carb, after port and polish u just hantam in weber. very nice.
jinkl
4,624
376
3,183
naik bukit easier.
do not give false hope to him la bro
port and polish promises more performance
but it never ever promises wheel spin , huge gains and such
so many factors more
port & polish gives better and higher flow of air ,
iz282
4,966
18
naik bukit easier.
0-100km/h in shorter time..? WoW..! :stoned:
naik bukit easier...? What kind of buKit bro..... :biggrin:
press sikit accelerator car already can fly....? Wallaa..... :love:
easy to get wheel spin...? :rofl:
hantam WeBeR...? hehehehee.....
:tee:
Darth
368
2
3,018
Selangor
straight to the point....it improves ur air flow inside the head..thus improve performance....
this is my experienced....for efi and carb the porting n polish style were diffrent....for carb cant be done same like for EFI.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
exhaust can be same... but intake is different...
for carbie, intake lubang must not be polished till mirror finish... must have minor rough edges to allow air and fuel mix together properly prior entering into combustion chamber...
as for fuel injection, fuel is squirted by injectors in a form of mist/spray.... hence, it can be easily mixed together with air to have a better combustion...
D-IV
262
How do you know you are gaining better air flow when sending the head for port and polishing?
D-IV
262
If they have a flow bench test before and after porting and polishing, that'll be great. Not that i don't know about flow benching, just wanna make sure only. Its ridiculous to send the head for headworks without supporting evidence of any gains.:stupid:
Anyway, intake port needs to have some rough edges so that air velocity becomes slightly turbulent and increased air velocity to allow proper air fuel mixture but that also depends on how you design the bowl and throat angle as well.
Exhaust port needs to be polished so that hot air is expelled faster as the polished surface reduces chances of soot deposits ( it won't stay polished after a few km but atleast its better than OEM). And might as well polished the combustion chamber to mirror finish so you are more knock resistance and changed to JE forged piston.
In addition, you'll need to port match the exhaust manifold and intake manifold to the ported head.
Dear sifu,
After I install the central locking, my door lamp function when door open. Door lamp cannot function when i switch on... central lock is ok... Do my wiring got problem? because 4 wire i only use and 1 white wire no use...
please help me.. dear sifu...
