- Apr 6, 2007
- 3,752
- 8
- 1,638
ooopsss,...prehaps a leak
get it chked quick or risk overheating the engine,...
could be ur fans, ur water pump,...
many things,...
actually u can take out the egr valve to clear off the carbon with a screwdriver, just scrub them off...Havin the same problem as you bro, where is the HV racing at? May need to change the EGR valve as well. Wondering if there's a performance difference with the EGR thing solved
what screwdriver,... = toothpick???actually u can take out the egr valve to clear off the carbon with a screwdriver, just scrub them off...
just use something to access into the valve to scrub off the carbon..what screwdriver,... = toothpick???
bro ...........what is EGR....where is located???? isit the sensor on the exhaust piping under the engine??? :hmmmm::hmmmm::hmmmm:just use something to access into the valve to scrub off the carbon..
that at the exhaust piping is the oxygen sensor,... o2 sensor,...bro ...........what is EGR....where is located???? isit the sensor on the exhaust piping under the engine??? :hmmmm::hmmmm::hmmmm:
sorry bro cant get where isit..............any pic that can help ..pls thanksthat at the exhaust piping is the oxygen sensor,... o2 sensor,...
the EGR = exhaust gas recirculation
is located next to ur valve cover,... left hand top corner,... looks like a cup
this is from accord enginebay,... not 100% sure whther the EG enginebay is like that or not,.. eventho i used to own an EG,...sorry bro cant get where isit..............any pic that can help ..pls thanks
