H22A engine Check Light ( EGR )
Lancerboy1
248
These few days got engine Check light in my car while i cruise..hard whacking doesnt show check light...
Went to workshop where they link a Handheld computer to diagnose...
It was my EGR valve Fault.
i know i can just buy a new EGR valve to solve this but Can anyone tell me how to solve this in most economical way?
pls share if u got similar problem. i was told by workshop that this no need to fix one, wont affect much... how sia??
Merry Christmas to all BTW/ =)
hky
219
Hi, is your check light on all the time. i also got problem, sometime on sometime not. if check light not on, can the computer still show the problem?
Lancerboy1
248
ok let me describe more clearly...
Whenever i start engine, NO CHECK LIGHT, normal...
After i move off, Slow speed.... cruising...suddenly check light will on, NO BLINKING, just on all de way.
Then i off engine, RE -CRANK my engine, no more check light again.
I tried WHACK MY CAR, no check light.... but after i slow speed relax driving again for about 5-10min, check light come find me again...
So i went to workshop where they use handheld computer to check... it said its EGR problem..
I dont know if can clean the EGR valve or not... but i do know a new EGR valve is expensive....
anyone selling a good condition one?
darkemperor
318
EGR - exhaust gas ricirculation is for reducing the nitrogen oxides emmision by ricirculating the exhaust gas into the combustion chamber...part of the OBD1 emmission control system..
nyway there are 3 components in the system generaly will indicates EGR fault for either 1...EGR valve, vacum valve n sensor...there will be no effect as far as im concern if you have any of it faulty but the CEL keep on lighting make one sick..:biggrin:
advise for u to check all the vacuum hose and connection........
J101
1,304
malaysia
prolly your intake manifold is clogged, dirty and insufficient flow. u can try cleaning the egr ports. on top of that while cleaning, clean the throttlebody and intake manifold. if it still doesnt work, then its a faulty egr valve.
i have heard ppl removing it and blocking it. maybe u can ask the h22a owners for better tech infos.
fobs
3,752
get one from the chop shop,... wont be THAT expensive,...
Lancerboy1
248
Hi all thanks for replies!!! i just called HV racing.... he said a used EGR valve ard RM150 and he will replace it for me... let u guys know again if it solved afrer replacement... the engine check light is really sickening to see..
fobs
3,752
yup,... reasonable lerr,...
update us, coz our egr also might konk anytime,...
Lancerboy1
248
i hope a recon one can solve my problem... had yet to go and fix yet... next week after i go HV and fixed will get back to u guys..
bien335
1,819
48
1,648
Johor Bahru
yo bro lancerboy, looks like u got ur H22a already :D
got the EGR replaced?
i usually carry one spare. and also a spare dizzy coil. :D
Lancerboy1
248
eh who are u ah??? just now my water temp UP slowly almost to the max... then i refill water, realised the spare water container next to the radiator... how come ah
Lancerboy1
248
ask workshop use vacuum/pressure tester to test the EGR to see whether the diapgram stil in good condition.
u can just ignore it but emission control will failed
bro, thANKS ...will ask the mechanic test
bien335
1,819
48
1,648
Johor Bahru
ROFL
IIRC, u were asking around for a cheap H22a to plonk inside a prelude.
rising water temp? is the reservoir bottle empty before the temp rise or was it full?
if its empty, something is wrong bro. a leak somewhere perhaps.
if the bottle is full, then there are many things to consider.
just fill up the reservoir bottle first and see what happens.
Lancerboy1
248
ROFL
prehaps a leak
Hi all,
anyone have the measurement for arc super induction box:hmmmm:...might wanna build 1 for 4G93.
---------- Post added at 06:48 PM ---------- 6 hour anti-bump limit - Previous post was at 04:31 PM ----------
Hi all,
attached in sketch drawing of own version
please help give idea...filter goin to use...
