TD05 20g on 4g93t
30
5
1,508
would installing td05 20g on 4g93t cause much turbo lag?
i would like more power but prefer not to have any more turbo lag. and how much hp can i expect after change from stock turbo. last dyno around 220 hp.
mivec head better??
Seems too big, even 2.0 Evo only use td05 16g. What turbo are you using and how much boost?
late reply but currently on stock turbo td04 1.3 bar boost.
gsr ck engine
How much more power are you looking for? If not too much maybe rather than going bigger turbo, better go for cams and water methanol kit, then tune for a bit higher boost like 1.4-1.5 bars, maybe can bump up to 250.
minibeany
598
102
543
what car body is that? if Wira 1.3/1.5 body that is almost the max... cannot take it...
30
5
1,508
ok ill look into this.
