Humble DIY Repairs On My Car
M_Engineer
28
12
39
I would suggest to put additional jackstand or spare wheel as a backup in any case the liftjack fails/ fall down. just a safety measure
Made a video to show how QuickJack lifts since you asked. The bar in the middle of the jack is the mechanical lock that keeps the jack upright even without hydraulic pressure.
  • Love
Reactions: TitanRev and leinnz
leinnz
333
57
3,028
nice one
Reactions: M_Engineer
how do you release the lock? Just lift each side individually? This is electrically actuated? Nice
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Nice one M-engineer
M_Engineer
28
12
39
To lower the jack, first step is raise the jacking frame to the highest position to release the mechanical lock. Then manually pull the bar up on each side to reset the locking cam (silver piece at the end). From there just lower down the jack.
The frames are lifted using hydraulic pressure provided by an electric hydraulic pump powered by a 12V battery (car battery will do)
Garage mods and trying out vlog video style
Same brand of chainsaw as mine.
Mine already making money after bringing down 4 trees.
You dont have to push it back and forth like a normal saw. Let the weight of the saw do the job or pivot it using the metal claw thing.
With Chinese saw, u need to make sure the oiler works or u will burn the chain. These chinese saw is as powerful as the ori one and is worth the money for DIY guy.
From experience, using normal 2T is better than expensive 2T as engine felt more happy when being revved.
I changed my bar to 18inch with Oregon chain but still keep the ori chain and bar.
You probably shouldn't be showing how fast you were going which is obviously above the legal limit anywhere in KL. If anyone was a dick and reported you to PDRM, they'd be able to use this as proof and issue a saman.
MEngineer
Nov 11, 2012
17
9
503
Yes buddy totally agree with you. For the price I was also amazed with the performance felt as good as a branded one. I too got back value on my investment. Prior to this I hired people to cut down they charged RM700. Now I have a free chainsaw.
The problem I had was that the chain was blunt therefore I need to put more pressure and move forward and backward to cut the palm trunk. Also mine somehow the chain tensioner the bolt thread got stripped, I think I over tighten haha. Overall no regrets purchasing it.
MEngineer
Nov 11, 2012
17
9
503
Yup I have tried to be careful by censoring out my car number plate. So even if I go over the limit not easy to trace. Sure they can check through my face but it is easier for police to catch people just on the road lol.
check your oil pump. I increased to almost max flow as we are not expert and does not know how hard some trees are.I Learn that the hard way when cutting a rambutan tree to smaller pieces after the tree was struck by lightning. Burnt the chain, after that oil pump fail.
Parts are cheap and available online.
hi to all sifus ,
just wanna know that do Honda Civic 1.7 version able to transplant a B18cR engine in ?
if any sifus know whr can do it , hope sifus can provide more info on this dream project of mine .
thanks alot :wavey:
