DIY to seal tyre puncture
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Do you know what the beef jerky seal is made off Vr2turbo? I've only seen black ones
Really no idea what it is made off. Only the patch seals from inside and umbrella seals also from inside I know are made of rubber.....
loose_end
3,649
197
Malaysia
Thank God I used cheapo tyre, got a nail for my 3 month old new tyre.
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
I have an electric pump and these worms from Mr DIY, very nice peace of mind whenever I go on road trips.
If the tyre burst into pieces then RIP lah, can't help.
Trick is to pump it really hard while attempting to close the hole so it will fill up. (Dont forget to use the pump with the engine on, later dead)
Quite a tiring process actually.
Reactions: Izso
Yup, the tyre with more air pressure will be rigid and easier to poke the worm in. I did before, once with less air so it was difficult to poke the worm in. After pump up was easier to poke it in......
Ya man, I tried it once also, damn hard to push the worm in, especially because I didn't take off the wheels from the car hence must push just with my arm from the side, cannot push down with my body weight! Very tiring leh. The next puncture I went back to tire shop, lazy to DIY again eventhough still got a few more worm! Lol
Front tyre can still turn out the steering. Rear tyre have to take out......lol
Hi all. I see that the RadioStar section has little to no activity in the last few years. But I am hoping there are still folks out there monitoring it.
I have been given a new RS0591 and have installed it. Almost everything seems to work fine, except I problem trying to engage Turbo / Short Run.
The unit will flash the lights, and turn the LED on, but after a couple seconds the LED goes out, and when I turn off the key, the engine stops.
I presume the LED goes out first because...
