Humble DIY Repairs On My Car
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
This is okay until a certain level. The 32bit continental ECU of Proton can use this, 16bit cannot. Some pins are unavailable on the send or receiver side, my car cannot set throttle relearn or reset my immobilizer.
to be honest it's more than enough for most people's needs, at one point i needed it pretty often to clear an error caused by the 02 sensor in an aftermarket exhaust.
can you actually set throttle or immobilizer with the ob2 dongle and app?
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Thanks for the kind words sir. I do hope my videos are beneficial to people. The bluetooth scanner hardware acts as the Vehicle Communication Interface (VCI) only. The brain is like you mentioned the application. So technically it will be able to do the same thing if the app is the same. The catch is good apps from developed companies like LAUNCH, AUTEL etc will only work with their proprietary scanners.
keep up the great work :congrats:
For me, so far work well too, espcially for my Chery SUV. Need to find fault code, if can handle, DIY. If not, send to mechanic friend, tell him the fault. After repairs login and erase the code.....
Reactions: Tom
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Yeah to check engine fault code is fine, but also the basic ones. My immobilizer fault code didn't show up in the Torque app, I was very frustrated why my car cannot start, hahaha.
Reactions: Tom
lsm1991
1,469
185
some errors and input commands are just not found in the db torque has i guess.... otherwise it should pull everything. end of the day its just a simple signaling mechanism..
Could be the app not suitable for the make/brand of car. It works well for my Chery SUV, for Forester certain things ok, some things not....lol
lsm1991
1,469
185
I think its the limit of the dongle.
dongle is just an interface... everything else is on the side of the app... remember, just signals. signals are just 1's and 0's... if you can interpret the combinations of 1's and 0's (decode it) i will mean something
M_Engineer
28
12
39
Yup it has the function, I managed to reset the throttle on my Proton Gen 2, similarly it can work with imobilizer too but never got to try that function out. What I understand it does not cover all the vehicles so it likely be a hit and miss depending on the app support.
Yah, even the actual unit my mechanic have, have to choose car make and model to scan. New cars in the market, have to get new software upload....
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
No, u need to have a dongle that can actually translate everything to the app. ELM is what we used and they have only a set of protocols.
The one that I have don't work well with my Forester, but club member did mention got another model that can read most of the data, including CVT fluid temp......
guys...im having this problem...the doors warning light..is ON even when all the doors properly shut...
only the warning indicator light OFF when i startted the engine....it comes back to normal...
problem occured when engine is off...shut all the doors...ON the alarm...the warning indicator light still ON....
what seems to be the problem...is it the wiring problem...already tested all the doors point button...push it several times and monitor at the warning indicator lights near the...
