4g13 talks
lsm1991
1,469
185
Then tell me is it worth it to install the cam tat i have shown above. What are the pros and cons after i install the cam
frankly speaking, i think most of us have already said a piece...
i do wonder tho.. what are you expecting from this set of cams. And its a serious question, not trying to be snarky or anything.
frankly speaking from the cams ALONE you wont get much, more 'major' mods usually require supporting upgrades...
and the cam pulleys alone, like parakee mentioned will only 'shift' the powerband, which usually means you end up with garbage low end or no top end....
engines this old with little tech suffer from this kind of issues. you tend to have to make sacrifices in other areas to gain in certain others.more modern engines tend to have tech to 'compensate' in areas where they lack.
leinnz
333
57
3,028
at least on the positive side, he will learn a lesson by doing this. dont let him down with a frown. let him gain knowledge from his modding.
pipercam brand.. but i just spoke with my pomen.. he said if wanna cam scare after installation need to change the injector and add piggyback somemore to support the cam. Lot of hassle. He advices me just to change cam pulley to adj one.
sigh..
this is what I was talking about. Study la bro. My 4G15 only had a cam pulley. Didn't use any ECU other than standard ECU. But that's because the overlap or lift is too much for the ecu to balance out. You'll need the piggyback or a standalone to manage the idling. But with a mild cam you don't have too much to worry about. And you don't need to upgrade your injectors la, you're not going full on high cams.
Seriously find another mech/tuner if this is what this guy is saying....
But again - back to my earlier question - why do you need the cam la? It doesn't do much if your engine is this stock. Maybe a small power gain here and there but SOHC just basically means you move the powerband around a little, not so much have massive gains. You want massive go for turbo
lsm1991
1,469
185
hehe not really my place to say this, but i takut he mod and throw lots into the car, then realize, the gains dont really reflect. nanti paranoid xmau mod car liao. This kinda engine imo best left mostly stock.... light mods only....lightened bits here and there are fine (dont significantly buang weight off the flywheel or anything that extreme)
well known fact, the roi for na cars is already so low... and these simple BUT not simple enough engines are not exactly the platforms where the gains are that significant.
**just realized its a carb > efi conversion.... the carb would have been nice here
Reactions: leinnz
sigh..
That was why bro. lsm and me talking about snails/siput......lol
Carb mod weber can get more power......lol
leinnz
333
57
3,028
In other words, let him burn?
let him gain the knowledge he want to have. he is curious to know what are the effects/gains/loss from his modifications. EInstein fails many times before his major success. same goes to jack ma
I think most of us went through that stage already......hahahha
yea... in this case particularly... carbs would have made more power... and is probably more mod friendly if the purse strings xmau bukak besar
My mechanic and myself played around those days. The weber in the 3rd Gen Civic was fast. I did it to my 2nd Gen Accord face lift model, that one probably body weight heavy, improve slightly only......lol
Helo ,
I have recently noticed that the water level of my car reservoir tank is dropping whenever I drive .
So I top it up daily , usually will be less than a half of the tank .
I tried figuring out the problem and noticed that the radiator cap rubber has harden and shape had been out of place .
Its a 0.9kg pressure big sized cap . So it was replaced .
The water level then never dropped in the reservoir tank after the change .
I thought it was done , when then the water level of the...
