Falken FK510
ixeo
4,788
3,080
KL, Malaysia
Why not just use 245/40/18? Much cheaper and common size, closer to the front 225/45/18 and better fit for 8.5j rims on your F30.
boss
https://tiresize.com/comparison/
225/45 R18 fronts
255/40 R18 rears
are identical in diameter
245/40 R18 will be 7mm less for the rear...
2 front 1 brand, 2 rear another brand is okay. I use many times like this when changing brands.
I check a few shops, Falken some at 800, 730 cheapest. One shop no Falken say PS4 810, that is why I let you know......lol
You got PM boss. I think rear got better traction is safer. They say new tyres go rear.
boss
225/45 R18 fronts
255/40 R18 rears
I know diameter wise it's slightly smaller but width is closer so less understeering tendency. Anyway 8.5j also better match fitment with 245. I'm also now using 225/45/18 & 245/40/18.
ixeo
4,788
3,080
KL, Malaysia
FR setup naturally oversteers right? I kinda like the way my car handles now.. a bit of throttle it will still oversteer..
leinnz
333
57
3,028
Oh really? Still why buy copy tires? It's already cheap anyway right?
can save rm10 for motorcycle EO also ok. motor also cannot rempit already. for taman use
ixeo
4,788
3,080
KL, Malaysia
So far so good. Wear still ok. Did a few braking, stops with plenty of room left. Wet also good so far, I only have experience with PS3 and not the PS4, FK510 is definitely just as composed as PS3 in the wet, I have confident and feel safe with it.
Reactions: 6UE5t and vr2turbo
29,998
Should be the 3rd Falken model quite highly recommended. Those days was the ST115 model, then the Ziex ZE-912, but this model later failed. Now the FK510 seems to be making a comeback for Falken
ixeo
4,788
3,080
KL, Malaysia
Isn't there a ZE-914 already? Yes 912 was quite bad, my friend one was having issue back then.
ixeo
4,788
3,080
KL, Malaysia
Well no more sweet rubber smell. Run in well. Tyres are doing well, no uneven wear, I must have hit some pothole somewhere both front and rear right rims bent... had to repair, lucky tires are fine.
Consistent, no complaints and I am gradually pushing them more in the corners.
I think at the price, I will definitely give it 5/5 rating. Don’t compare with PS4 please, if you’re willing to pay ~40% more just buy the PS4.
parakey
1,367
226
How does one hit potholes with rim denting impact without realising it? Tummy upset again?
ixeo
4,788
3,080
KL, Malaysia
I think I forgot about it after the impact. Brought car to tyre shop then they told me.
Hi guys, I'm planning to do 1.3 piston conversion to my 1.6 campro.
The workshop guy said he needs to open the block to check and see if there is any freeplay of the pistons, if so, the block needs to be rebored either 0.5 to 1mm.
Is it safe to rebore block? Or is it even safe to bump the compression of my campro? thanks guys :adore:
Can increase compression without management ma?
