KHNG940413
668
56
johor bahru
eh seriously ah? i still see RM185-RM215 price range for 195/55r15. 50 profile price range can get for RM165-195/pc
My jazz is 195/55/R15 I get a pcs 180
After few month I ask for the same profile at the same shop. It went up to RM220 something.
leinnz
333
57
3,028
harga getah naik bro
sweelt
Nov 6, 2016
2,306
248
Instead of long explanation just copy from Mr. Google.....lol
Symptoms of a Bad Oxygen Sensor
When you have a bad oxygen sensor, your vehicle will run less efficiently, it can sometimes have a poor idle, erratic jerking at steady throttle, hard starting problems, cause the check engine light to come on, and will cause high fuel consumption.
ECU will playsafe, run at rich mixture too.
Reactions: minibeany
KHNG940413
668
56
johor bahru
Wira Update.
Anybody facing issue while acceleration the car shake. Like the pedal and other bottom part thing start to shake? When drive slow no problem. Juz when you accelerate it start to shake.
My mechanic say is the drive shaft rosak.
Changing a pair of drive shaft + gear oil + gearbox oil seal ( forgot the name, some seal put at flywheel or clutch something.)+labour=RM650
Is it the price reasonable?
Wira Update.
Price is not too bad. New drive shafts or refurbished ones?
I dunno about the shaking problem though - might be driveshaft, might be some sensor somewhere (check with the PDT1000 device for errors if any) and might be fuel filter. I dunno.
KHNG940413
668
56
johor bahru
New one. Diagnose already. Ni problem juz always the speedo & high voltage issue always pop up only. My fuel filter had been changed.
May I know if chg drive shaft will they open the gearbox? Is so I also wanna buy a set of clutch set and ask them to help me install while changing the drive shaft.
drive shafts just need to jack up the car only. Is there a problem with your clutch? To change it out you need to lower the GB.
KHNG940413
668
56
johor bahru
Bcoz the old clutch is around 40% tread while install to my car. So might as well change it if they got open the gearbox. Consider to take a set of excedy clutch set.
Go back to stock la. Excedy maybe too hard? I dunno. Get something with a lot of springs.
It's not part of the drive shaft replacement but if you wanna do it might as well do it together. Maybe save on workmanship
Hi Bosses.
I am a newbie for this forum.
The story is like that
i just place the booking fee to a second hand car dealer for a CR-Z
Details:
Mileage: 16k
Manufacture date: 2012
register date: sept 2012
So the CR-Z exhaust pipe and the open port has been modified
beside that,
the power bank/ power charger also been installed.
Under these modified,
Does the car engine warranty and battery warranty still valid?
