Perdana v6 : Road to 300whp.... and beyond
marsha1l_v6
666
130
543
Cruising at the limited top speed of 250kmh for 20min will dry up the tank.
to cruise at that speed...titanium ball
I better off going with ball bearing, because i am not planning to change the turbo as that will require me to change out the manifold as well. One mods lead to the other, after modifying the turbo, fuel injectors and ECU needs to be modified as well. Never ending journey,
good choice.
if you not going for high power, remain stock injector is good enough..just get it remap(if its possible for your stock ecu)
Mitevo7
1,456
179
good choice.
I am going for fast response, the power is there on every command, like a small turbo kind of response. Stock ECU as far as i know can't be remapped by many tuners. I will need at least an adequate piggyback to molest the stock ECU.
Forget piggybacks and get a decent Links ECU la. It's one of the better and cheaper ECUs right now and definitely has more range than a simple piggyback
Mitevo7
1,456
179
I only need very simple AFR tuning due to my current intake and exhaust piping are non stock, so car is not running optimally. Link ECU might be overkill.
sweelt
Nov 6, 2016
2,306
248
good choice.
Bro... Don forget one fella have adamantium balls. lol...
I guess AMG assume by default all of the AMG owners have titanium balls hence it limited to 250kmh.
Those with adamantium can go ahead and remove the limiter and reach adamantiun level of 320kmh.
Anyway, i also want to know what is the fc for such powerful perdana. I bet it can beat my Pajero. A trip of about 90km (Mlk to Bahau) at speed of 80kmh and below will consume at least 1/4 tank...thats about RM50-60. Offroad? 20min or crawling palm oil plantation using 4x4 mode will consume 1/4 tank too.
Its 2 different world of motion but one thing in common....'excellent' fc.
marsha1l_v6
666
130
543
if you think current ecu is not up to par with your expectation, better go link ecu.
from my POV, either rechip or standalone.link has good support and affordable.
but i sold mine and using rechip now funding for haltech elite :evil::evil:
that guy one second adamantium balls, another second saggy ball. hahaha
my car i only confidence up 180.
200 is my limit because the car felt 'light'
fuel consumption worse 8km/liter , chill drive( underboost) 10km/liter:driver::driver:
Your pajero is diesel or?
Petrol...all 2555cc of it.
Engine code 4G54.
90kmh at 3k rpm so u can imagine the fc.
Fastest i go is 140kmh at Lekas and its too much to take with the engine noise, wind noise, and body movement.
lsm1991
1,469
185
Engine code 4G54.
4g yo!
**90kmh at 3k rpms if u ask me is low hehehehe
Thats about the same as my Pajero. Cool, we have something in common despite different speed...hahahah.
I think i can beat your chill drive figure if i dont use aircond on the Pajero. I still remember i got 11km/l driving like an old uncle and aircond Off plus upshift at 2k rpm.
Also, i notice that carrying more weight does not affect the fc. Putting the roof rack which messes with the wind will double fc. Is it the same with yr car? I think its down to the torque figure and availability range.
At the rate you're modifying your car - you might as well prepare for more with a full on standalone. Considering how it can do everything, it's not overkill. Just peace of mind.
To all current IS250 owners, models from August 2007 to February 2009, your Lexus may need certain corrective measures to the Fuel Pressure Sensor or its fuel system as according to Lexus Malaysia - UMW Toyota Motor. There are issues found with insufficient tightening of the said sensor, causing further looseness over time which may lead to a fuel leakage. The fuel may leak via a gasket in...
