Perdana v6 : Road to 300whp.... and beyond
sweelt
Nov 6, 2016
2,306
248
Ini semua gila turbo punya olang...
But i am also interested in turbo la, just takut it break because my foot also quite heavy.. even na car i also managed to break my driveshaft already..
knn...how to foot heavy in island :rofl: hahahaha...
brokenjars
229
16
Kedah
At night after 2am road clear a bit hehe.
That time when my driveshaft broke, i think is either a wira gsr or wira evo challenged me. Because he has at least 6 gauges at his dashboard. If na cars usually also have 3 gauges only. Since its turbo, need go all out already..and i broke my driveshaft when upshift 1st to 2nd gear..
Penang island Terror........hhahahhahahaha
marsha1l_v6
666
130
543
That's approximately 13 litres per 100km. I assume your daily commuting is around that
slightly better...underboost most of the time due to traffic. Can go up to around 360km for 40 liter.
Cool mods !! Talking about FC, my 1JZ with mixed driving still able to pull 380 km from RM100 RON 95. Its not even full tank yet.
thanks, its on going mod. now at 75% progress
build it right and good maintenance, u can tekan till your heart content.
anyone here play v6tt how much hp can get from stock internal?
probably around 19x or 20x whp. best is to leave stock for reliability. modding it will be costly.
if you're going to mod it, better get evo engine. cheaper, reliable and part easily source. Any service center/workshop can service your car without cutting your throat.
Mitevo7
1,456
179
thanks, its on going mod. now at 75% progress.
Do you have any idea which i can make any stock turbo to spool up faster ? My stock 1jz starts spooling at 2.5k and full boost by 3.5k rpms, it affects abit when picking up speed.
marsha1l_v6
666
130
543
that 1k rpm difference shouldnt take that long right?
this might help:
turbo side:
port and polish the stock turbo
ball bearing journal
twin scroll turbo
downpipe (noticable different on response after i change to bigger downpipe)
Mitevo7
1,456
179
this might help:
turbo side:
twin scroll turbo
Turbo side:
port and polish the stock turbo - this is to smoothen out airflow ?
twin scroll turbo
downpipe - > DONE, when converting into my E46, this one is larger like 3"
In between twin scroll vs ball bearing, which one can be much easier to be modified into CT15 stock turbo ?
marsha1l_v6
666
130
543
Turbo side:
twin scroll turbo
PnP; yes, smoothen the airflow to promote better response. i did not do this because theres mix feedback on this. some say it works, other say better rebuild turbo or buy new one.
twin scroll require u to change exhaust side turbine/kacuk to other model. better off find good twin scroll turbo.
ball bearing would be easier to modified, change the internal stuff.
Mitevo7
1,456
179
I better off going with ball bearing, because i am not planning to change the turbo as that will require me to change out the manifold as well. One mods lead to the other, after modifying the turbo, fuel injectors and ECU needs to be modified as well. Never ending journey,
lsm1991
1,469
185
upgrading to ball bearings is already a step in that direction
yesterday i had to drive my wira through the flood in front of menara PGRM.. aiyark!.. now my headlight got water inside n my horn sounds kinda funny and not loud as usually.. how to flush the water out? n y my horn sound like that? got water inside also?
