sweelt
Nov 6, 2016
2,306
248
Yes,now still cannot figure out why the hood is open when driving. My friend suspect is when I go over a hump or pothole causing it to loose and pop up.
For now it don't have any issue. I will switch to a stock wira bonet & bumper since the fiber bonet is cracking.
And the Old mivec Bumper I will sell it to cover up my expenses. Hahahahaha
There's 2 round rubber for hood. Check either is worn out or too high. It kept the hood tight while work as damper when you close.
Wah! if bump can loosen, that is very dangerous......
minibeany
598
102
543
Ori the price is like skyhigh. A used mivec bonet also cost around RM400+
Standard can already larr....Hahahahaha
Engine kuat can already
go check at FB marketplace... ori wira bonet shall be around RM200. i saw a seller in JB trying to clear store... check it out
lsm1991
1,469
185
These are the lock mechanism for my hood and yes it look very weird. Hahahahahaha
i have to ask..... when you pull the hood release, do you still need to pull the latch up front to pop the hood up, or can it be freely opened at that point?... if you do need to pull the latch infront, was your hood structurally sound? (the second latch works so long as the hood doesnt flex side to side, if it does, its almost good for nothing)
KHNG940413
668
56
johor bahru
Yes,I still need to pull the latch before I can open the hood.
Hi
I've problem with my brakes on my Toyota Cressida. Just fitted a Big double layer servo and a pair of twin port caliper. Yet the brakes seems sluggish.
Desperate help needed.
Thanks
