4G92 Mivec
Triplej94
Jun 22, 2017
13
Kuching
I have a proton Gen 2 which I bought from a friend. when he bought it before it was already running on a 4G92 mivec engine. so both of us did not know what type of 4G92 it was specifically.
I've did some research, probably it's a CJ4A or a CK4A. I'm confused. :dontknow::dontknow:
characteristic of the engines is, Mivec change over at 6800 RPM. I've check the ECU code which is 2556. however, I was told the engine is a 4G92 mivec RS. :confused:
sanekit
Dec 9, 2015
1,616
157
thanks for the info.. any idea on the differences of the RS version and non RS version? I heard that the RS version comes with a higher cam?
i don't really know. usually engine specs all the same. only the interior and exterior is different. need to check online about this.
Probably same like VR4 and VR4RS, engine same but have bigger injectors and larger turbo, different ECU of course.....
lsm1991
1,469
185
and likely the gearbox... rs typically has some sort of lsd where as the gsr, i think sometimes tarak? i could be wrong
Nightstalker1993
267
130
Subang Jaya
Looks like nobody answered your initial question.
Mivec RS vs Mivec normal, Mivec RS have titanium intake valves, different cams with more aggressive lower cam which is why the mivec switchover is at a higher RPM. Water/oil cooler at the rear of the block, oil squirter jets on the block for piston cooling. Mivec RS engine also sometimes comes with an LSD gearbox as well. Gear ratios are also slightly closer if not mistaken but I had forgotten the details.
hi all sifu and member,
i have vios 2011 model that is with ori exhausr stock, now i plan to modified the exhaust with low noise and pickup and end energier more better for fc, so what is agak agak price and ok lah the material piping as my budjet not more that rm800, plan change ori stock i think is 4-2-1 one
