4-2-1? 4-1? Extractors broken down!
stainless steel or mix steel? any different on performance and sound? or just durability
Supposedly stainless steel doesn't rust therefore will last longer. But experience has told me it's rarely ever pure stainless steel. It'll rust somehow if exposed badly enough and long enough. But then again nice and shiny piping sure looks nicely than mixed steel piping.
In terms of performance it's just a matter of weight (assuming you have the correct length and diameter sorted out) cuz both pretty much heat up nearly the same rate, cool down nearly the same rate and all that. The only one with a real difference is titanium piping.
minibeany
598
102
543
ah... then save the money... thanks.
sanekit
Dec 9, 2015
1,616
157
i would stay away from titanium headers unless the weld is done by a reputable person/shop. it would crack easily if not properly weld. headers runs hot compare to pipings running back to the mufflers.
Mitevo7
1,456
179
Generally mild steel is good enough for most applications, you can heat treat it by ceramic coating it. I have used mild steel headers without coating on my old sentra for 13 years without burning out anything in the engine bay. The heat in the engine bay can easily solved by custom heat shield for metal sheet too. Performance wise, i don't feel any much difference compared to SS headers, may be the car is just SLOW so whatever mods also does little improvement.
sanekit
Dec 9, 2015
1,616
157
it's not just the material, design also matters. piping length, diameter etc. :driver:
sanekit
Dec 9, 2015
1,616
157
What’s your advice for Wira 4g15 stock engine? City drive. No long distance and no track
those mild steel replacement is ok. better flow than the stock cast iron. the SS headers usually got larger diameter piping and longer header design. you'll suffer a bit at low RPM.
this is from a seller on mudah. he advertised it as racing extractor. u can see the length of the pipes going down is longer than stock.
this one is from another seller. advertised as JASMA extractor. design is almost same as the racing one, but has a shorter pipes.
and this one is your standard besi putih extractor which has a shorter almost stock length piping joints, cheap and cheerful and definitely lighter and better flowing that your stock cast iron. i've used this before on my previous 4g15 auto vdo engine. no complain, does it's job.
Reactions: minibeany
Mitevo7
1,456
179
For non performance engine, using SS is just for aesthetics purpose. You are absolutely correct on diameter, length and stuffs, however i don’t think any company will put serious thoughts when building any headers for non performance engine. As long as it fits the target market demand, they will gladly sell you something they claimed is TUNED length or bla bla bla.
Still, the art of modding is still CUSTOM.
Change my wira one before. 4 to 2 almost same length as original, only the 2 to 1 goes right down which is much longer. Mine the length just reach the nenas so plug and play, no need shift the nenas, save cost......:driver:
ixeo
4,788
3,080
KL, Malaysia
4-1 and 4-2-1 both suck... put a turbo header and a snail and it’ll blow!
Reactions: sanekit
Looking for an alarm system for my car. Clifford is far too expensive for my budget so was offered an American Autocraft alarm system called the Matrix III + Cheetah immobilizer/anti-hijack system for RM2100. Installer claims that features are almost the same with Clifford system, except cannot program + minus some features. Does anybody have any experience or comments about this brand or setup? would appreciate any feedback, thanks.
