KHNG940413
668
56
johor bahru
Why change the whole compressor for recon unit if only the magnetic clutch got problem? Compressor working fine.....:driver:
The 1st mechanic I go to check say compressor rosak. I dun belive so I bring to another place to check. Found out only the old clutch rosak only.
So I juz change the clutch yesterday and everything is ok now.
LittleWhiteWagon
1,656
187
P.J
To be honest. What were they thinking making the car so high.Hahahahaha
It gives better suspension travel & comfort for consumers. Back then when cars were still relatively softly sprung, they can absorb bumps very well in a straight line & mid-corner. I've a feeling why it wasn't lower because of ground clearance when fully loaded.
But then again there's a lot more engineering behind that than just how high/low soft/stiff a car is that makes it handle... Our IRS proton rears under compression gains camber + toe. Quite a good design for that era.
Reactions: sanekit
LittleWhiteWagon
1,656
187
P.J
Stand still pick up ok la.
Juz lack a bit of torque after you release the pedal and step back.
Now my friend suggest me to go and check does it need a top overhaul. The engine is running ok but when driving & idling a little tapping sound.
If you want to save cost can perhaps try diesel engine oil at the next oil change first. The engine may be a little dirty over the years.
I've used bardahl diesel oil + marvel mystery oil to revive a 3 years dead wira. From blowing white smoke it took 1 week of driving to get it to have 0 smoke & condensation like new in the morning. Sometimes the piston rings are just a bit sticky, don't necessarily have to overhaul straight. :burnout:
Reactions: sweelt
ah finally a proper 4g1x taiko is in the house
Reactions: sanekit
My hyundai change oil from 10w40 to 5w40 started smoking. Now Change to 20w50 with a bottle of no smoke to keep it from smoking......lol
Eh, now people move to electronic cigarette. No more conventional smoking. Maybe u can try few drop of vape flavor into the engine oil...adds some taste and aroma...hahahah.
sanekit
Dec 9, 2015
1,616
157
#offtopic can try heat not burn ciggies too. but the starter kit cost like RM200-350 including the heat sticks.
sorry for i always mess up what they said
there is alot ppl tune out this matterz.
On wheel horsepower (calculation on formula)
FLywheel horsepower (calculation on Formula )
Engine Horsepower (Calculation on formula)
If 200hbps = how many wheelpower , how many flywheel hp ?
If 200 Whp = how many engine power , and flywheel power ?
get my meaning ?
On wheel = when driving?
flywheel on testing ? or what
Engine on tuning ?
any formula or explain ?
what the full name...
