Dreaded Steering Wheel Vibrations at High Speed
The center ring make the wheels snub fit. My tayarman use white teflon, he machine out the ring.
When pull out the wheels need more punch up, down, left, right. Hahaha
mine made of aluminum, had balancing issues before using them. need to centralized then on wheel balancing. then every time take out, mark the hole also no use.....lol Now with the cone, off wheel balancing ok already, take out put back no marking also no issue......haha
Mitevo7
1,456
179
The wheel further out is original rims offset or by using spacers?
2 things that made the front wheels sir further out:
1.) Negative offset of the wheels
2.) The disc rotor center hub is wider than stock and came with centric hub design, sort of like a spacer.
As long as have centric hub that fits the rims center, they are ok. Many spacers are just flat so it does not keep the rims centralized......
Dear All,
Just found out one thing, the centre bore size of the rear wheels are not matched, therefore causes all the vibrations to the body. The front one matches due to i need to use after market wheel bearing to mount the disc rotor, and the bore size at the front is 74.5 mm. The rear is 72.5 mm. We jacked the car and put the gear in D to see the movement and noticed the wheels are hopping up and down. We just need to install the right fitment of centre cone and see whether it cures this shit.
Thanks,
Ken
Your vibration problem settled?
Mitevo7
1,456
179
Yes it was settled, how amazing that just a 2 mm difference in hub bore size can caused so much trouble. Now i am able to drive the car with confidence !
That was why my first question to you was, got center ring?.....lol
Mitevo7
1,456
179
Initially no, coz the mechanic insist it doesn’t need centre ring cause its oem. Finally he gave in and check for free play and found it. Haha
parakey
1,367
226
Simple case of removing the rear wheel and measuring. Your mechanic is quite a stubborn fella
Mitevo7
1,456
179
I yelled at him to finally threaten him i am not paying until you cured the issue. And there we go :)
Yeah, most mechanic will jack up the wheels and use hand to rotate and confirm about the issue.
That's what he did, and the stock wheels and lug nuts are very tight when testing. Therefore he wasn't suspecting the centre cone either.
parakey
1,367
226
Notes this down. Yelling sometimes works :biggrin:
Compared to the power transmitted by the engine to the rear wheel, how much power can arm wiggling transmit? Wiggling test only good for badly worn arms; generally stuff which driver should be able to feel at low speeds. Let's say if rear wheel bearing is making a bit of noise. I dont think wriggling is able to detect that; not unless your bearing is about to fall into pieces
Mitevo7
1,456
179
Provided if you are close friend to your mechanic, otherwise he can make your ride even worse
My mechanic now become family friend some more. Very mild mannered and had never raise voice before, now 30 plus years already.....lol
Sometimes If he free, he come and collect my car go repair......hahhahhahaha
Reactions: Mitevo7
minibeany
598
102
543
can also jot down in buku 555? hehehe....
guys,
is thre any product that can remover Watermark stain on my windscreen ? its really hard to c wen its raining without wipers ! :cry_smile:
need help from anyone that have faced this problem and solved it !:emoticon_U:
thanks for the help in advance ! :shades_smile:
