parakey
1,367
226
With regards to Wira, my 2 sen is to check the chassis/body. The other parts can be easily replaced.
If car was recently resprayed, please check the roof, rear fenders, doors & boot for patched up jobs. Pay particular attention to the roof. If you find putty there, walk away. On second thought, dont walk. Run instead
sweelt
Nov 6, 2016
2,306
248
Open the boot and check the spare wheel area for rust. If there is a lot of water be careful as it will need a lot of rubber to be replaced or that it could be caused by a severe accident. Check that all lights is not an aquarium - if there is water in the tail lights or front, check that nothing is shorted or rust and crusty wiring.
If raining season, good to spot for leaked. If really want the car, ask owner park outside for rain exposure.
Feel the car carpet, raise up all car mats check bottom got water vapor/spot, car smell ?. Dash board position, doors...
Like sifus mention...rust and accident dents, chassis condition. Need good eyes and experience.
1.5 4g15 VDO Auto 2007 i think is a C97 body. Not aeroback
15inch rim, Nissan 2pot brake, adjustable (will swap out), exhaust is stock. I think the owner had change the rear to s flow.
Sounds like a de-mod car.
Check thoroughly or organize a TT session by inviting ZTH members to view the car.
I believe he's in Johor. You're the nearest ZTH member.
Eh..nobody from JB?
You guys all got snail bolted to the engine....a trip to JB is good to clean the carbon build up from travelling in the city. My EX5 will take years to reach JB...hahahah
parakey
1,367
226
Eh..nobody from JB?
Sec while I open my bonnet. Nope. No snail in there.
Snail is VR2turbo and 6UE5T
KHNG940413
668
56
johor bahru
The paint is still in decent shape. Juz the rear boot have some little crack the
This is the picture I took when I go and take a look. Is in quite decent shape...... I guess?
KHNG940413
668
56
johor bahru
Will look deeply on this sunday. Since I got a lot of time and patient:biggrin:
hahahahahahaha
This is the picture I took when I go and take a look. Is in quite decent shape...... I guess? View attachment 575819 View attachment 575820
Thats a Nissan brake servo there but i fotgot which model. A friend got the same servo in his saga which is paired with Evo front caliper. PCD is now 114.
I can see the PCV hose is missing from the valve cover to the intake pipe.
Open pod filter with no heat shield is s**t to drive when the weather is hot or stuck in jam.
KHNG940413
668
56
johor bahru
The open pod I will also swap out for the Original air box. The pvc hose is at which area? Sorry I not sure where is the pvc hose missing?:adore:
Hello folks :itsme:
I was wondering, if 4G93 SOHC hi comp pistons would fit on a 4G93 DOHC?
They have the same piston diameter (81mm) and stroke length (89mm)
--- mmn81
