EG overheating, oil temp 100’c and water temp 80-95’c
Ranjanmax
121
Few months into ownership of my lovely chilli. Owh wait, now I got overheating issues.. Noticed that if I drive hard/long enough through out the day, my oil temp starts shooting up.. stop at the traffic light or stuck in jam, water temp also rising up to 90+++.. using SARD radiator (short one), not sure if it’s helping or worth pointing out but I feel the need to install a oil cooler ady.. if not no fun driving the car.. *insert frown face*
lsm1991
1,469
185
adding an oil coler at this point is more like a expensive band aid solution.Like izso mentioned check if what you have now works efficient enough.
any idea what the eo temps are?
Reactions: Ranjanmax
Ranjanmax
121
To be honest no actually..
Ranjanmax
121
SARD radiator - the likelihood that it's an ori - probably 10%. You might have a bad airflow rad and fan.
Might I say I should do a flush on my radiator and do all the necessary checking?
Yup, do the necessary check up first. Fan running at proper speed, water pump, thermostat all running condition, coolant not like teh tarik..haha
As for oil temp 100c is normal. On my wife's forester, doing 110kph is around that temp. Going uphill like Menora tunnel from Ipoh to North can go up to 108c, and tried one time to Genting at higher revs can hit 116c
ixeo
4,788
3,080
KL, Malaysia
is the original fan shroud in place or removed? check if the fan motor is weak...
Reactions: alcyon
lsm1991
1,469
185
actually
1)why do you say its over heating
2)how are you reading the water temps? dash gauge?
Ranjanmax
121
So reaching 100’c should be normal temp?
lsm1991
1,469
185
1.shouldn't oil Temp be between 80-90’c?
2.using defi gauges to read the temps
very strange, you have the water temp but no oil temps.....
usually na guys go for the oil pressure, followed bu oil temps then water temps
mADmAN
1,840
547
my previous B16A i set the temps gauge to buzz at the temps below
oil - 130c
water - 97c
n i only achieve that during track days and also hot weather mega traffic jam.
was using an oil cooler as well as a short AVS aluminium radiator
My current Evo with Tomei Titanium Expreme Ti. But I think the sound too loud until I cant withstand it anymore.
So I have few suggestion from friend to modify it to made it more quiet. But I not sure which one the best or the most quiet way. I hope any Sifu here could suggest me or provide some idea to me.
In my mind I have 2 option to choose:
1. Change the mid pipe with Center...
