Suitable absorber for wira 1.5
kaihoong
93
28
Hi all Sifu2
I now driving wira 1.5 sedan using waja front kyb gas absorber with wira SE spring and rear using kyb gas absorber with wira 1.6 spring. Now I get front 3 finger rear 2.5 finger. But when drive in highway feel like abit float, duno whether is stiff or float like not stable.
1. Is it rear absorber is too soft(last year change KYB gas but still soft when pressing rear by hand).
2. I want to lowered my car, if I get sport spring can I get lowered since I am 4g15 engine with big absorber and spring. What I know is Wira SE spring is shorter than wira 1.6/1.8 stock spring.
What is the best solution for my questions. Or choose adjustable, my pomen recommend me to use HWL hlsf 15 step adjustable. But adjustable is out of my budget. Thanks..
Hi all Sifu2
Since you are already using Wira SE front spring, that's already pretty low. The lowest sport spring that I know is the APM Performax. Changing full set APM Performax spring and absorber would make your car really low and will possibly make speed bumps a pain in the ass.
The easiest way to properly lower and get good handling is to change to coilovers and the HWL ones are the cheapest out there. Probably RM1.8k to 2.5k max. Go directly to HWL factory to get it installed, don't go through your mechanic. Cut out the middle man so maybe can get cheaper.
Oh! the factory also sell direct? Won't the dealers make noise?
kaihoong
93
28
If i get apm performax spring only, rear I sure will lowered but front only many pomen say very hard to say since big abs and spring, thet recommend me to potong spring
If get springs only the absorber may not last, as not matching, and for any matter, never never never potong the springs.......
kaihoong
93
28
just now I saw have people sell redsuns adjustable high low bodyshift front 6k rear 4k(used condition)...is better go for adjustable?
let say use sport absorber + sport absorber, will feel very bumpy or not
Usually lowering springs need to be harder because car is low already, couple with harder absorbers the ride sure will be bumpier. Only thing is to get the correct spring rate to help it to be more comfy....
kaihoong
93
28
Hi low bodyshift adjustable is more harder than sport spring with sport abs?
FYI, my tyre profile is 195/55/15
They don't care since it's just one or two customers max.
What is it you want for your car la? Why want to lower but care about comfort and bumpy ride and all that. If you lower it will affect comfort and if you match it with the wrong absorber it will make the cars life very miserable. Wira SE spring is good but it's old. After a while any old spring will eventually wear out and become soft.
If you have money get HLSH coilovers. If you don't have money - stick with what you have now and leave it la. Save up your money and buy coilovers in future.
Not all coilovers are bumpy and some can be good enough to be comfortable (to some extent) and still handle well. Get those coilovers with bodyshift since you like to make your car low.
If you choose to use APM Performax, use the absorber together with the spring. Don't use the spring only. Normal long stroke absorbers will spoil very fast with APM Performax springs and will not handle very well either.
kaihoong
93
28
I dun care comfort driving in city, but I want more stable driving in highways.
