1jz E36 BMW frankensteining
Mitevo7
1,456
179
The Premium brand is basically a slight twist in the Titans brand. The workers for Titan apparently branched out to do their own thing and "Premium" was born. So means you're probably using inverted monotube setup.. nice
Apparently, the guys at Titan quoted me quite a good figure, but too many people have Titan so i decided to try out with Premium. Its indeed inverted setup, it handles the weight of 1jz very well and the rear isn't sliding when i apply heavy throttle in corner (may be i am not driving fast enough). Gotta work on the brakes now and also, need somebody to help in turn on the traction control on the ECU too. Think you can hook me up ? I saw your blog, there's one E46 1JZ Twin Turbo, he did it but he is a electrician.
Thanks,
Ken
Nightstalker1993
267
130
Subang Jaya
Instead of buying alternator, modding it and all, why not just try my suggestion of fitting an ficd? Like I said the issue seems to be your engine rpm dropping when the fan kick in due to the load from the alternator. Ficd and install should be less than 200 kot
Mitevo7
1,456
179
Oh sorry to inform this late, my mechanic said he already fitted an FICD when modifying the car's A/C system, so your suggestion is also part of the solutions, just that the stock 1jz 70amp alternator just wasn't enough to power some of the accessories in stock BMW.
Thank you very much bro,
Ken
Nightstalker1993
267
130
Subang Jaya
Ken
Yeah install another ficd for when the fan kicks in. You said you if give it slight throttle to maintain 1000rpm it is ok right?
Ken
Only 70A to run conti electronic...too low.
As a comparison BLM is 90A, Waja 1.8 is 120A.
My Pajero ori alternator was a mere 55A which is enough on stock setup but with lightings and double blower, its barely enough. I once used 70A alternator and the car felt better. Now back on stock alternator as the 70A recond one kaput within 1 year long time ago.
Thanks,
Ken
Technically he's not an electrician and I don't know if he'll do it for you but try asking here :
https://www.facebook.com/repairecu1...NLE9mxYMdIIHsDdOcZOPLm2K8YKplRCbejuP&fref=tag
recond warranty not as long halfcut. iirc, halfcut 1 week or so, recond few days je..hahaha
one of the best using 4g63, parts are everywhere from proton/mitsu
But I have better luck with recon units, but not with half cut ones.....lol
alcyon
800
153
543
Yes that's what i gathered too, today just someone decided to reply me from chop shop, after 2 months of hunting ... Thanks, once i complete the swap i will inform here.
Latest mods, installed P9 Premium Shock Absorber at Premium Garage, i am not exhilarating, the comfort felt pretty much like stock and handling was better. I got much better control on speed and corner, last thing will be brakes.
Thanks,
Ken
Does it use pillowball top mount or original rubber ? Also what is the price and spring rates?
Mitevo7
1,456
179
Just their aluminum top mount, i got special prices, i think you should contact them directly. Spring rate is 12kg front, 9kg rear.
Thanks,
Ken
Mitevo7
1,456
179
hmphh, was hoping to use rubber. not into all this "racing" stuff.
I learnt from my previous lesson, stock mounting will not go well with the adjustable spring, it will constantly bind itself when turning steering wheel which annoys the f out of me.
Thanks,
Ken
alcyon
800
153
543
Thanks,
Ken
I thought that only happens with mcpherson strut ? If double wishbone no problem right ?
Hi everyone. 2 weeks ago, I was hanging around my mechanic's place doing nothing better than sleeping, gossiping and talking CXCK and laughing laudly... Realizing my mechanic was busy dismentalling a CAMPRO 1.6 engine to overhaul, I decided to get my hands dirty and help him up...
As we were busy dismentalling the engine, we chat about CAMPRO 1.6 BOT failure on Crank and we realizeD BOT DOES NOT FAIL THE CAMPRO CRANK, BOT ONLY ACCELERATE THE FAILING PROCESS OF THE CRANK....
