Myvi Icon 1.5 Auto use Straight Flow or S Flow
May 28, 2018
2
27
Im using original 4-1 ,cat only rear is using straight flow, should i change to s flow, i heard that many people do recommend auto car should use s flow
Any Suggestion?? that i need to change my straight pipe to s flow
Don't be fooled into believing this S-Flow or straight flow hype. Back pressure is not good for any exhaust setup.
The question is what do you want to achieve? Quieter exhaust? More flow?
What kinda engine do you have?
S-flow mufflers slow the flow of the exhaust down and have better sound insulation and emissions control. But on a turbo car this is like choking the engine.
etc
Jason3293
2
27
etc
i was thinking change to a quieter exhaust and have more back end power
im using stock myvi 1.5 engine 3sz-ve
ixeo
4,788
3,080
KL, Malaysia
Find a DSPORT full cat-back if you can still find them. That's the best. Otherwise, just change back to stock.
OR
Slap a turbo on it, it'll be quieter.
What's "back end power"? Low RPM / Mid RPM / High RPM power got la. What exhaust setup are you using now?
OR
I don't think DSPORT made a setup for the 1.5 Myvi right?
ixeo
4,788
3,080
KL, Malaysia
DSPORT didn’t. But it fits. Then some people gonna say because it’s designed for the 1.3 it’s under sized for the 1.5. BS. It’s even suitable for turbo, being bigger in diameter than the stock YRV exhaust.
Would be interesting to see any for sale, much less someone actually offering up their one for sale
ixeo
4,788
3,080
KL, Malaysia
I got a Carvox CX-990 ( aka Radiostar King-Eagle ) 2 way lcd alarm a 2 month ago. I got it installed and it was working fine. Now it got cold the remote starter will not start. It only starts when the engine is warm. What happens wile the engine is cold is: it will crank for a second and shutoff and siren goes off at that time.
I got the system on ebay and got it professionally installed all together $300+
I took it back to the shop they checked and rechecked all connections for 2hr...
