DIY: Changing Myvi absorbers.... solves the kluk kluk sound.
Ride height not that much different. I'm using Alza mounts on my gen 1 myvi and it didn't change the height at all. Took a while for it to settle though.
Yes, you need to compress the spring to detach the absorber mounting. Btw, you can opt for alza's mounting (bearing mounting) instead of rubber type mounting.
Benefit:
1. Durable than rubber type (myvi ori is suck).
2. Improve handling.
3. it's plug & play (cucuk dan main).
cons:
1. Higher ride height.
Since fits both cars, wonder why they produce 2 models? Usually manufacturers will try to reduce parts production....lol
jerrysiow
407
146
Seremban
I've no idea and the ori rubber mounting just get loosen feeling after like half year of driving or 10-15k kms clocked.
jerrysiow
407
146
Seremban
Alza top mount makes the suspension a bit stiffer
I feel the car height is higher than before as easier for me to come out from the car.
Hmm, maybe we use firm better than stiff as I did not feel it's stiff but more firm and stable.
Reactions: Izso
Looks like the Alza ones are much better......lol
Kevinho
94
Puchong
The original absorbers? If yes, then you need to compress the springs....
Yeap, it's the original absorbers.
Is it possible to do it with the car not jacked up ? I somehow think that the absorber mounting is gonna shoot out when I unscrew the absorber mounting without the car on jackstands
Kevinho
94
Puchong
Benefit:
cons:
Thanks for the reply man.
Yeap I got tips from foreman saying alza mouting with bearing is better lol.
You need to jack up the car to remove the suspension. The top mount is lock down by a nut on top or do you mean the mount have torn apart?
Kevinho
94
Puchong
I saw a guy posted in his blog, he didn't use spring compressors, he unscrew the absorber mounting, slowly jack up the car and the strut slowly comes out. After he use another jack to jack the lower arm to put the new absorber mounting into place since the spring compressor was not there with them. It's in baikisendiri blog but I think now the blog was removed, couldn't find it.
I haven't tried doing it yet. This is just what I read from the blog. Any sifus here can confirm ?
Wah.. that's a crazy insane amount of work to remove the top mounts. You can do that but why?
Kevinho
94
Puchong
Thanks man.
Appreciate your response.
Needed some clarification before trying it out.
Are you guys going to conduct a Meet up & DIY sessions ?
Can't wait to join you guys to learn more stuff
We can’t get enough of the new BMW M5 F10 and after the static shots of it hit the interwebs, we now have some rolling footage of the super-sedan taking to the course, with a few seconds of mandatory hoonage just because it’s an M5.
Although most of the video consists of the M5 just cruising around the tight course, as we mentioned, there’s a few seconds where it’s let loose. You get to hear the twin-turbo...
