Low oil pressure at idle and Mivec mode not cutting in 4G92 MIVEC help!
jay_lancer
292
70
28
Thailand
Hi I have a Lancer with a swap to a 4G92 MIVEC as per the picture:
Recently the oil pressure has started to go low when the engine is at idle/tickover.
This is shown on my oil pressure gauge as well as the oil light on the dashboard had been flickering.
Also the car won't go into MIVEC mode.
I have checked the oil, it is at the correct level on the dip stick and was only changed about 3000 KM ago, running 10W40 fully synthetic oil.
Everything was working fine previously, then after a long fast run on a clear motorway where I was able to go into MIVEC mode, when I turned off the motorway and stopped at some traffic lights noticed the low oil pressure at idle.
The oil pressure for regular driving looks fine.
Any idea's about to fix this issue?
Many thanks
Looks like need to change the oil pump. Better do fast as Oil starvation is not good for the engine
jay_lancer
292
70
28
Thailand
Hi
Thanks for the reply's, have read that my engine can suffer from oil pickup in the sump getting blocked, will look into it, won't be driving it much until sorted out
cheers
y2188
441
42
28
Is your oil pressure level same as before? 1bar seems a bit weak but still fairly normal, if the pressure is the same as before, try check your mivec solenoid.
lsm1991
1,469
185
yeah 1 bar isnt horribly bad yet..... depending on the amount of wear, 1bar per 1k rpms can be considered 'sort of normal'
jay_lancer
292
70
28
Thailand
definitely a little lower because the alarm was activated, also oil light on the dash board came on.
Have been advised to try an oil change to 5W50 fully synthetic oil, will do that, and check the MIVEC solenoid.
Many thanks!
change oil pump..
new billet pump preferred...
Since normal drive the pressure is normal, could it be the oil pressure sensor problem?
lsm1991
1,469
185
since oil pressure goes up with the rpm (till a certain point) si if it actually is starving, it will seem fine when you are giving it some revs. Afaik, it would only know if the pressure is fine or too low without taking into account the rpm speeds (on my old junk car at least, it isnt able to relate the rpm and oil pressure)
and since he has 2 sensors (one stock, providing ecu data hense the dash light and the other for the defi, which is also going off)
Many thanks!
jay, dont think changing to heavier oil will solve anything, but instead only mask the issue if it works. (my 2 cents)
sanekit
Dec 9, 2015
1,616
157
oil pressure need to check under load. free revs sometimes pressure is ok. :driver:
lsm1991
1,469
185
oh didnt know there would be any dif
**actually... am quite sure there will be no dif, oil pressure should (afaik-lah) be affected by the temps (affecting viscosity) and rpms.
jay_lancer
292
70
28
Thailand
I think I will try an oil and oil filter change, maybe just partly blocked oil filter?
does anyone know the best oil filter to buy for 4G92 MIVEC Gen 2?
If that doesn't work will have to look into changing the oil pump.
cheers
lsm1991
1,469
185
cheers
any filter will do really... am running proton filters on my car...
GSR TURBO problem help me and how tu up boast with ma problem
hello bro may be u all can help me plz ya if u can do so...
so im driving GSR turbo engine,, all in standard specifikasi...
so what happen my wiring turbo gsr has wiring problem so the ecu GSR burn n bust(meletop)
so check the wiring cannot settle with the problem...
so what i did ,,i use back mine putra wiring n bought E-manage to settle ma problem... so settle all the problem
NOW what i wanna to know ...
