Perdana v6 : Road to 300whp.... and beyond
marsha1l_v6
666
130
543
Yes bro... Just the turbos, intake (if it fits) and maybe pistons.. cos not sure 6a12T pistons can support two TD04
just checked with my mechanic this morning, yes can fit and use..but the rear turbo prone to fail due to heat.
didnt check on intake and pistons.
Seems they have not hard to find. My mechanic ask me before also, whether I wanted those but got to look for it.
cant find during my search at couple of shop @ sunway and mudah :bawling:
marsha1l_v6
666
130
543
guys need help @ 1.5k is there any good daily drive clutch can handle 300lb/ft torque?
choices are
- competition clutch stage 4
-exedy 3/4 puck
i've done reading and google... best is to get full face clutch ceramic pad ( daily drive reason).. but cant find it in mudah other than organic..for now choices are above from mudah. yet to survey at sunway shop.
I'll be rebuilding my gbox this month.. installing semi lsd and send flywheel to machine shop to be lighten, remaining clutch set only, current one started to slip.
do chip in your opinion. thanks
kurt_629
872
54
johor
choices are
-exedy 3/4 puck
not sure if helps, recently i change my clutch plate as it has already worn out.
I ever use those sport clutch before, OS Giken..
if you are looking for daily drive, would advise you to stick to original/stock type..
its really difficult to engage or to step on..
stock can also handle 300whp, no issue.
marsha1l_v6
666
130
543
iinm , cover plate that makes soft/hard to step on.
well nothing much available for sub 1.5k price in market here....
gonna jump and go for cc 6puck sprung clutch:smokin:
Yes, the pressure plate, but if with harder springs it helps the clutch plate attached better, but heavy on the legs.....lol:driver:
marsha1l_v6
666
130
543
a quick update for those who follow...gbox has been rebuild...end up with 6 puck..now softer than oem clutch...but better traction
next post will reveal dyno chart
choices are
-exedy 3/4 puck
exedy organic with copper mix clutch plate....
exedy heavy duty clutch cover
Nightstalker1993
267
130
Subang Jaya
6 puck from what company? Trinity? Works?
If I had seen this earlier I would've asked you to get the Exedy 4 puck. It is 'properly' made and have a sprung hub so it's better for daily drive and the pads are a good balance, no judder etc for daily drive.
Where's the dyno chart? :rolleyes:
Just read through the whole thread, looks like you have not gotten/decided on an ECU? I would highly suggest you save up probably for the Link EVO plug-in. No wiring job required and you get tons of features, if not mistaken it comes with launch control and also boost control so you can throw away your EBC already :biggrin:
marsha1l_v6
666
130
543
:itsme::itsme:
6 puck sprung hub cc clutch...btw autobacs klang selling off cheap for act clutch. NOS <New Old Stock>.
yet to go dyno...waiting for payday...spend alot this month already..my cap ayam wastegate gave up on me..had to buy genuine one...
yea the ecu....thats the reason why dyno chart will be available later...now got 1k off srp...had to purchase it...dyno result will determine whether i'm gonna upgrade internal or leave it oem..
it has all those feature..probably just keep my EBC..it has afr/boost/ebc...might link it with ecu. :smokin:
Dyno chart....
Didn't expect this much hp.. Was expecting 24xhp at 1bar.. :smokin:
However fd2 dyno before me get 11x - 13xhp..doesn't show this dyno is 'ringan'..
Anyway another dyno run at April to confirm.. 2nd opinion they say:nurse:
Maybe half cut engine was modded before? Like my first engine had shaved header......:driver:
i'm planning to get a autogauge BF RPM meter for my iswara. There's few stupid question i would like to ask...
Is the reading visible clearly during day? Cause i drive my car mostly when the sun is up...
And any iswara"rians" around... can the meter be fitted just in front of the original RPM? i mean like just in front of the plastic visor for the stock meters...
thanks people
