HIDs
Anyone know if you can put HIDs in the satria neo, and what kit to use?
Sent from my SM-G935F using Tapatalk
the stock neo oem projector not gonna cut it....it was barely optimum even for oem spec...
i would suggest u to look around for projector retrofitter in your area, then discuss with them to swap into better projector unit meant for hid unit...
lukel95
75
28
GB birmigham
So the projector glass would need replacing before HIDs go in?
yeap...definately....
btw u can try look into HIDplanet forum for more info on that
Okay thanks, how come btw, are the HIDs temperature too much for the glass to handle
i would say more about the optical design of the oem halogen projector doesnt suits hid bulb well enough to make use of the extra light output produced by hid bulb....
lukel95
75
28
GB birmigham
Okay thank you, any idea what hid kit I will need?
marsha1l_v6
666
130
543
[/IMG]
One of my project. Retrofit hid projector. I would recommend using marimoto or you can lookup csb pro for retrofit hid but priced at premium and quality/finishing excellent. Now they have led kit.
HIDs very low heat right?
Does anyone know of any good HIDs that are 4300-5000k colour and bright?
goohtj
57
12
5,008
still finger burning hot
l am using those rm1xx type. the ballast is not lasting.
maybe osram or phillips ori could last longer.
if u were looking for HID unit upgrade,
the 2nd best option is this..
known as Fast Bright series ballast (available in 35w= F3 model, 55w= F5 model, 75w= F7 model)
https://www.aliexpress.com/store/pr...32345610822.html?spm=2114.12010612.0.0.q7Nnxm
this ballast start-up and became full brightness as fast as the OEM high end car ballast....with a fraction of the cost of oem ballast...
the 1st which is the best option would be getting the oem ballast (hella/ denso/matshushita)...
but need extra part...which is the D2s into H1 pigtail conversion on BULB side....
and offcourse...the price....
Guys,
Check out this dudes blog. Its all about his mods and his passtime of chasing and testing power with people. Have a good laugh guys.
http://chaser-racing.blogdrive.com/archive/cm-8_cy-2006_m-8_d-7_y-2006_o-20.html
