4G93 DOHC with intake and exhaust reversed?
RENESIS VIII
7,063
950
Ipoh
https://www.youtube.com/watch?v=Y2lnTAQa65g
I found this video on YouTube yesterday. I was quite confused with this setup. What kind of benefit can the owner gain from this setup and how did the mechanic managed to reverse the position of the intake and exhaust? The valve cover is still positioned like normal though.
Not sure what engine he use, but there are engine layout in that way, meaning intake front and exhaust at firewall. 1st Gen Accord is that way and even my Chery Tiggo SUV the exhaust is on firewall side.....
RENESIS VIII
7,063
950
Ipoh
The video says it is 4G93. But 4G93 intake is on firewall side while exhaust is facing front. The one on this video is the opposite. Intake facing front, exhaust on firewall. :confused:
Naaz
5
4
503
4G93 CA engine with 4G93 CK head
CA engine (wira/satria/putra chassis) = timing belt on rightside
CK engine (lancer/ mirage chassis, engine ngam2 fit into waja/persona/gen2/neo) = timing belt on left side
so when CA + Ck head, in order to meet the correct CA timing belt side, so the CK head is reversed installed.
Not much in performance but do helps in presentation.
mag9556
2,770
43
1,648
I thought it was 4G93 since the head is similar to it. Wait for more sifu to reply here. :biggrin:
It is indeed 4G engine with Mivec head actually but the setup:hmmmm::hmmmm::hmmmm:
can gain more horse meh:confused:
RENESIS VIII
7,063
950
Ipoh
Nope, that is not a CK head. Initially I thought so too but after looking carefully, I found out that the head (valve cover) is from the old 4G9 series not the new 'terbalik' version.
Here, look at this area that I highlighted. There is this gap area to accommodate the plug cables in the earlier 4G9 series engine.
But it is not present in the CK series of 4G9 engines.
Probably he manage to use that cover on the K head. If you look at radiator top hose it goes to the rear at firewall side
RENESIS VIII
7,063
950
Ipoh
Maybe you are right... Such a weird setup. So many things needed to be custom made. If he is using ITB for intake, then perhaps I understand why he wants the intake facing the front but he is not using ITB setup...
slipar
500
61
banting - pj
that is 1st gen mivec rocker cover..mivec head got 2 deck..maybe they mix both 1st & 2nd gen deck together or what i also dont know
but i still wonder how they put it together and got it in running
Naaz
5
4
503
it used 4g92 mivec ck head mix with ca block. it is not 4g93 head.
this modification becomes trend lately.
1 of my friend's neo, using CK block with 4g93 CA head mix with ITB config. manage to churn out almost 200whp a t wheel.
LittleWhiteWagon
1,656
187
P.J
All I can think of it's just for relocation of the extractor haha. No heatsoak going under the engine + the weight of the extractor is shifted more towards the middle of the car...
RENESIS VIII
7,063
950
Ipoh
Looks like a lot of work to do for the sake of slight improvements. I wonder if the engine mounting needs to be customized or just plug and play?
sorry guys and dudes here, i know this topic has been discussed a million of times but i have something to know.
i went to the shop and ask the boss there said:
LOWERING SPRING and SPORT SPRING is different
Lowering Spring the coils it lesser than stock (like potong spring product)
Sport Spring the coils is like stock or more than lowering spring 1 but it gives lowering effect also.
So is it correct?
and which spring is reasonable to buy in Market for LMST?
I asked the shop...
