Looking for new tyres for MyVi (195/50/15)
I have actually never heard of ATR Sport exploded.
Soft sidewall but very decent amount of grip. If its enough for my heavyweight Persona, it is enough for you. :biggrin:
For your size. RM150 is available bro at Kean Lee Hin Jalan Ipoh. Wet still can go.
Like I said before in tyre threads, wet straightline braking abit shoddy, but wet cornering is pretty good. :rofl:
Me, Ericmaxman's Saga, my boss' turboed RX8 using 19 also. :proud:
Probably either the owner curb the tyre sidewall and never took care until explode. I have heard of bulging in tyres not explode....:biggrin:
sennafan
11
503
Johor Bahru
thks for the advise Bro, most likely this is my next choice as I started to narrow down to ATR-Sport or KU31.
---------- Post added at 12:15 PM ---------- 6 hour anti-bump limit - Previous post was at 12:13 PM ----------
sifu, what is the advantages / disadvantages of hard sidewall tyres ?
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Hmm, the Ku31 seems to have 4 center grooves, which is good for anti-aquaplanning.
For ATR Sport, water dispersion will be better. But aquaplanning isn't bad.
Advan: Better steering feedback(No sidewall flex), better laptimes.
Disadvan: Bumpy ride
As mentioned by bro. SC, hard sidewall better for cornering less flex, but ride more bumpy.
Some can say pump more air for soft sidewall. Yes, but air cannot be compress, means you pump 38psi instead of usual 33psi, can corner but the ride will be terrible if you compare to harder sidewall tyre with correct air pressure.
---------- Post added at 01:22 PM ---------- 6 hour anti-bump limit - Previous post was at 01:19 PM ----------
Aquaplaning and wet traction is two different thing.
One is to clear water so that the tyre rubber is still in contact with the road surface
Two is the rubber compound ability to have traction with the road surface, so here a softer compound is better.
New!
Mothers carcare Hi-Series-Reflection
Available in malaysia
Pls call 012-4711151.
Pls log on MOTHERS® Polishes·Waxes·Cleaners
Car Wax-Super wet look!
Durability-2 month
Top Coat-New
Deep Shine and Extreme Gloss-Look Very Reflective!
The Best In USA
Over Merquiers !
