My oxygen sensor
Don't ask Toyota la. Go find a generic spare parts shop. If I can find it cheaper will you come to my house and let me charge you to replace it? :biggrin:
Anyway, O2 sensors for smaller cars isn't as scary as the bigger cars. Speaking of which, my Nissan Sylphy O2 sensor costs RM200 at the spare parts shop near my house. I highly doubt the Vios will be more expensive.
1. If you want to check, you need a voltmeter and know how to read it.
2. This is a simple O2 sensor, most if not all mechs can do it.
3. Find a spanner that'll hold the new sensor snugly, WD40 the current sensor - let it soak in, spanner remove it (bit by bit, don't be too aggressive). Unplug it and replace with new sensor and installation is reverse of everything.
Very easy laaa... The biggest problem is finding a cheap sensor only.
Actually got quite a few sure would like to come your house to do it.....:biggrin:
Allexking
Apr 1, 2011
11
4
503
Can you check for me which oxygen that faulty FOC first ?? Once confirmed, I can buy from Spare Parts shop for Toyota then let you change for me.
Any best price for your installation fee ??
:hmmmm::hmmmm::hmmmm:
I don't have an oscilloscope la. Manual way of checking O2 sensor needs a computer. Just note the voltage of the O2 sensor (with engine on) and mark on Excel then plot a line graph. It should look like a smooth curve and evenly spaced out. If any irregular shape is plotted then it's likely spoilt.
As for installation fee, I was kidding la. Just buy lunch :biggrin:
Probably the petrol and toll cost more, depending where you stay.........hahhahahhahaha
Allexking
Apr 1, 2011
11
4
503
Conclusion
When engine light on, google around to check what caused it. One of it, is about ignition coil. Did manual check on those 4 ignition coil. That moment, all still functioning. Focus on other area that may lead the engine light on. Two foremen checked on why engine light is on.
Both of them also said most probably is the oxygen sensor that faulty. Both also advise must double confirm with those workshop with diagnose meter. Continue drive my car for almost three weeks without knowing the real cause. Last friday evening, the car feel jerk when on D or R, during N no jerk at all. During acceraleration, can feel jerk also.
Early morning yesterday do some manual check on those ignition coils again. Confirmed one of them spoilt.
To be continued later (Rush for works)
[FONT="Arial Na[FONT="Arial Narrow"]rrow"]Continuation[/FONT]
After purchase new original ignition coil costs me RM200.00. Replaced it myself in office carpark. After installed, disconnect the battery (-) terminal for around 5 minutes.
After that start my car to check the jerk & engine light whether still on.
Bingo!!!!!!!!
Both problem rectified
P/S - Above information can be used for those who are facing same scenario with me
Happy motoring
[/FONT]
Conclusion
[FONT="Arial Na[FONT=Arial Narrow][SIZE=4]rrow"]Continuation[/SIZE][/FONT]
Bingo!!!!!!!!
Happy motoring
[/FONT]
Jerking ka? Aisay. I thought what was the original problem. If jerking then 9/10 times it's the coil mah. Rarely ever is it the O2 sensor.
But nice job anyway!
Hyundai-Sime Darby Motors (HSDM) is previewing the Hyundai Ioniq Hybrid after beginning to accept orders for the car a day before. The Ioniq Hybrid is being displayed at an event held at the Malaysia International Exhibition & Convention Centre (MIECC) starting from Nov 10 to Nov 13, 2016...
