Hand dont itchy itchy go damage somethingIf got error code drown it in gasoline also can, but not when no error code.....hahahhahahha
That is why no error code don't touch it......Hand dont itchy itchy go damage something
Got problem baru troubleshoot.That is why no error code don't touch it......
Engine check light will light up.....How to check if oxygen sensor is faulty ??
Your assistance is highly appreciated.
Thank you
Yup!! my engine light is on. There are 2 oxygen sensor for toyota vios. How to DIY to ensure purchase and replace correct faulty oxygen sensor.Engine check light will light up.....
Normally, 2nd O2 sensor is located after Cat, a bit difficult to DIY.Yup!! my engine light is on. There are 2 oxygen sensor for toyota vios. How to DIY to ensure purchase and replace correct faulty oxygen sensor.
Thanks for your prompt reply
Change both, Less hassle......hahahahhaStraight change both la. Very easy to diy. Probably a size 17 or 21 wrench and WD40. Settle.
Both changed all in should be RM180 for two?
If both really only RM180.00, earlier already change them. Checked with Toyota Spare Parts shop. Quoted around RM300.00 per sensor. Vios got 2 oxygen sensors. Thats why seeking for best solution to me here which as follows:-Straight change both la. Very easy to diy. Probably a size 17 or 21 wrench and WD40. Settle.
RM180 maybe is Wira ones?If both really only RM180.00, earlier already change them. Checked with Toyota Spare Parts shop. Quoted around RM300.00 per sensor. Vios got 2 oxygen sensors. Thats why seeking for best solution to me here which as follows:-
1) Way to determine which faulty sensor
2) Any recommended reliable mechanic
3) DIY guide to change
Less than RM200 is usually campro or earlier proton models.RM180 maybe is Wira ones?
Don't ask Toyota la. Go find a generic spare parts shop. If I can find it cheaper will you come to my house and let me charge you to replace it?If both really only RM180.00, earlier already change them. Checked with Toyota Spare Parts shop. Quoted around RM300.00 per sensor. Vios got 2 oxygen sensors. Thats why seeking for best solution to me here which as follows:-
