Not hard to pasang it backif the part is cheap must as well change it since u have taken it out.
Let's see..any symptom your sensor already kaput...??
O2 sensor and cheap do not belong in the same sentence...
Only once to check..O2 sensor quite sensitive wei. You take in and out all the time something will break. Then fc bad and all that lovely stuff associated to a broken o2 then good luck
Ya lo...to me it feels okayNothing wrong pasang back.....
Actually no error code, should not take out. See also cannot tell.....Only once to check..
Sent from my Xperia TX using Tapatalk
Ideally, it'll last up to 100k km.Should we clean it in like how many thousand KMs? Or only use till it kaput lol.
Never heard of cleaning them. Probably can try if the error code say O2 faulty, then can take out clean and put back to try. If don't work, then have to change...Should we clean it in like how many thousand KMs? Or only use till it kaput lol.
Along the lines of soaking it in gasoline (do we have that here in Malaysia? ) for about 24 hours..Never heard of cleaning them. Probably can try if the error code say O2 faulty, then can take out clean and put back to try. If don't work, then have to change...
If got error code drown it in gasoline also can, but not when no error code.....hahahhahahhaAlong the lines of soaking it in gasoline (do we have that here in Malaysia? ) for about 24 hours..
