Grounding and VS can add power meh?Means this drag race is not stock wei. All got groundings and volt stabilizer
Anyway, ya the Almera ECU fried but did not blame my friend on it. Dunno what happen actually. Just trying to attach the last cable then short circuit.
Mine no need to remove positive terminal as well. Just the negative side.
Mine negative also did not remove....
---------- Post added at 02:50 PM ---------- 6 hour anti-bump limit - Previous post was at 02:48 PM ----------
Even touch +ve just spark only mah! Ground cable leads back to -ve terminal onlyI think one of the grounding wires touched the +ve batt terminal.
---------- Post added at 02:53 PM ---------- 6 hour anti-bump limit - Previous post was at 02:50 PM ----------
Battery 12v spark where can shock you? You want shock, try the spark plug cables....Why u usually relate to my mira Yes, worried about the Altis one. Kancil not afraid at all.
Cuz got once I was reconnecting my grounding cables cuz got loosen, then got sparks, gave me a shock and was afraid that I would get something fried. Lucky it is okay.
