Installing grounding wire
jebatdex
430
18
Skudai, Johor
Hi all sifus
I am going to DIY installing recently bought pivot 5 point grounding wire.
I bought it in the first place after google around where quite a lot of people installing it, especially for old cars like mine (1996 1.6 satria)
But yesterday, one mechanic i met said it is not necessary :idea:
Need some advise. Is it really necessary actually?
My logic thinking is; it is just additional negative wire which helps to discharge better. It wont disturb the engine system, rather makes the electrical system better.
Need advise on this. Is it good to go (install since i already have it), or not?
And also do's and dont's during installation.
Thanks all
ZainJR
May 19, 2014
31
9
508
Hi all sifus
Thanks all
used it b4 on 2004 waja (in 2010) and all i can say is so so only.. But notice the light a bit brighter be it head lights / meter panel. Add in with voltage stabilizer to monitor but since bought the HKS cap ayam end up no indicator appear.. :banghead:
If your car is accident free and is in tip top condition metal and wire wise, then it's probably not absolutely necessary to have a grounding kit. But most old cars have a lot of wear and tear so the stock grounding usually is compromised or worn. So if you use this aftermarket grounding kit it'll help restore the ground and make everything work back to normal again (key word : Normal.. not better). Do you have dimming light issues? If yes then your stock grounding is likely worn out. Just use it la, just make sure ground to the right places and don't create a short circuit.
Supra_Fanatics
20,673
3,998
My Saga BLM year 2010, at first I don't believe in making any difference but then after just installing one from battery negative terminal to the engine. The improvement is that it is not as lagging as before. Was better than not having it. After removing it since I'm selling the car, it is now back to square one. The difference can be felt for my BLM.
Anyway, like they said, for older cars it helps. For new cars, not necessary.
jebatdex
430
18
Skudai, Johor
Thanks to you and all
Will proceed to install on my 1996 satria which obviously very old now, the age coming to 2 decades now, and I am passionate to keep it in a good shape, and in its stock look. Thanks again! :burnout:
Supra_Fanatics
20,673
3,998
Happy DIY-ing bro. Best to get some guide or tutorial to do so. If not end up frying your ecu :rolleyes:
DanzEterna
15,911
3,371
www.primeperdanaclub.com
I had starting issues with my wife's atos, had to change battery & starter but problem still persists,
ended up bought the rm25 hks purple grounding cables then problem solved till today no issues.
so for me the grounding cable does works.
29,998
Grounding cables are good if car is old and wiring have build up resistance. Since DIY is cheap go ahead....
jebatdex
430
18
Skudai, Johor
Yes, my car is considered old now. Plus, it also got starting issues (tik tik starter sound when turning the key, especially when the engine is hot. Maybe also the starter needs to be serviced/replaced already). Also, the alarm sometimes goes on suddenly without reason.
So I hope can see some improvement on these. No harm to give it a try since grounding cable not very expensive.
Supra_fanatics, what can cause short circuit when installing the grounding cable? touching the cable to positive terminal or what? I am not that expert in electrical, so hope to give some guides (especially dont's) when DIYing this.
There are two ways to ground. Directly to the battery or to the car body. The way I did mine was to the negative terminal on the battery.
From there I pulled a wire to my alternator, from alternator pulled to aircon compressor, from there to firewall. Then the other side was distributor / ignition coil to the negative terminal too and one final one from to the firewall.
So it's just a loop from negative to negative. And you don't have to literally connect to the alternator or distributor, just the nut holding it in is enough.
Lots of youtube how-tos on grounding so check them out too
Supra_Fanatics
20,673
3,998
I'm not sure. My friend was about to connect one last cable and touch only, the ECU fried. Not sure why. But it was an Almera. Heard not to simply ground here and there, have to ground the right area. LOL!
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
which ever route for u'r grounding u choose, don't forget the first step to it, disconnect u'r car batt terminal & sifuses, which 1 is first, -ve first @ +ve first??
jebatdex
430
18
Skudai, Johor
+ve first I guess. Right?
Then, connect all the grounding wire as wished, and finally connect back the +ve. Thats my opinion
29,998
ECU should be well protected. He either touch direct to ECU or some fuses, but then fuses are also protected. So not sure what he did...:hmmmm:
As long as you do not touch anything live (positive terminal) you are okay
---------- Post added at 09:04 PM ---------- 6 hour anti-bump limit - Previous post was at 09:02 PM ----------
I did mine all direct from battery, means from battery to engine, to alternator, to firewall, to TB and to Distributor. 5 cables all leading away from battery negative terminal...:biggrin:
---------- Post added at 09:06 PM ---------- 6 hour anti-bump limit - Previous post was at 09:04 PM ----------
I did mine without removing the +ve terminal. With key ignition off the only thing live is the positive terminal and it won't fry anything...
Wira 1.5 A GLI
Hi sifus, i got a question, im not quite sure about my current exhaust mods cant trust those exhaust shops guys la, can anyone advise me on my current setup? Tried modifying few times till running out of ideas
Last time use to have two bullets but now replace with midbox some how feels better pick up! so now my setup is 4-2-1---Bullet----midbox------s-flow muffler
