Global Warming.. What Have U Done?!!
You do know how an exhaust works right? Regardless of cold or hot carbon monoxide is an exhaust gas which is reduced by the catcon.
And 'removing' pollution from exhausts?? Are you kidding me? You just solved the problem that every gasoline car manufacturer has been trying to resolve for ages! Woohoo. Dont be so naive, just because someone says so doesnt mean it is. Learn to provide credible evidence otherwise youll just be treated as voodoo mumbo jumbo
And provide the report link. If you dont understand it im sure someone here will.
Hai fellow ZTH,
Im using FN2r. Recently ive changed my air filter to simota air filter. Then the check engine appears. Ive dismantled the battery and hoping the ECU can adjust to the new air fuel ratio. At first it was ok. Then the check engine appears back. I havent tried changing to the OEM air filter yet.
My question is the ECU cant adjust to the new breath ? Do i have to use Hondata or equivalent?
Thanks,
Newby in I-vtec
---------- Post added at 04:40...
