Wrap extractor for longer fan's motor lifespan (& reduce engine bay temperature)
ken yeang
6,617
1,327
Jebatdex,
From the photo, I would recommend you to
1) wrap the extractor entire length. (fyi, 1 roll of wrap is about 20meter for about RM25. Maybe cheaper if you get discount. Need 2 roll to wrap it properly for your case)
2) raise the hood hinge, to let trapped hot air escape from engine bay (better result, DIY some louvers on the bonnet)
This would reduce heat built-up in the engine bay, and lessen the chance of melting the fan. The heat issue need to tackle bit by bit through trial and error.
slipar
500
61
banting - pj
im in trouble la like this..
been using aftermarket extractor for years now..
in jebatdex photo can see the gap between extractor & fan..
in my car gap cannot see anymore..like only few mm only..the metal cover behind fan motor also have to remove to clear the extractor..
i think wrap also the wrap cannot clear the gap..hahah..
time to change extractor la..will attach pic if possible..:bawling::bawling:
Then yours was badly done.....:banghead:
ken yeang
6,617
1,327
change fan location lor. Instead of pulling, use it to push air...
This is the photo:
The gap (highlighted in red) between the motor and extractor is (for me) very close. Or maybe I just wrap that particular area of extractor which is closest to the motor? hehe no need to wrap the whole extractor? :confused:
hi ken, my car is 1996 1.6L Satria 4G92, absolutely NA
4G92 oil filter is in such a weird location. Anyway my 4G15 extractor / fan is spaced similar to yours and in 9 years I've only had to change the fan twice. If you want, I have unused titanium extractor wrap which I reluctantly have to sell since my car is going away. Just PM me if you're interested.
What is heat shield made from? Can take an aluminium piece and wrap with aluminium foil or what?
I have a friend who took a sheet of alu, cut out a cardboard template of the extractor cover, using the template cut the alu and installed it like that. Works and looks great. I probably should have done that but I only have steel sheets which is bloody impossible to cut without the right tools (which I don't have).
That is why I prefer to use aluminum too. Lighter, easier to handle and does not rust....:driver:
jebatdex
430
18
Skudai, Johor
How your friend install that piece of aluminium sheeting? How to hold it in place?
May I now where is the best and affordable shop for car paint spray? I heard my fren spray his Kenari whole body at Kelana Jaya for just RM480..I saw the color and quality is not bad..Black color..
Any shop cheaper than that y'all know near Wangsa Maju or Ampang? RM500 is ok la..RM1000 and above is a bit nonsense lah..Kaut untung saja (pay high rent)!
