- Oct 27, 2007
- 822
- 229
- 1,543
so let me get this right...you already done top overhaul...??sounds like you already did from my understanding... any parts change during the process...??Hi bro... 20 valve does have tappets of coz. I think what u meant is it does not have rocker arm. I open it up to dissassemble and wash myself.
Where u get d price of new 850????!!! I got quoted 1.3k. So i forgo that option.
Anyways, to think of it, it sounds very much like valvetrain problem. My previous pulley makes noise but not this loud. I know d 20 sound, its just not this loud. And when i rev, d noise doesnt go away. It increases. The only confusing thing is why did the valve setting mess up? I changed the pulley. Didn't disturb the valve also.
Thanks bro. I will have my valve clearance checked. If its really the pulley, i might consider to change to adjustable.
Sent from my android using Tapatalk.
from what a read elsewhere... some 20v runners point out that valve adjusting shim also can be the culprit...it all seems legit because if you refer to toyodiy...there is practically a dozen sizes of shim available...
i can imagine shim knocking the valve lifter each time the cams rotates and causing the tick tick sound...amplify that with a worn vvt pulley...and diesel sound it is... lol
