with turbo who need full exhaust....Exhaust leh?
downpipe only enuf
But then surely the kelisa will be faster than the 1.8 then? in terms of power to weight ratio.
If it were to perform the same.
Dangerous to play if cant control
130hp on light chassis versus 140hp on slightly heavier chassis...should be similar....
Because the 1.8 Wira is using manual transmission so pick up is faster I guess? About top speed, I'm not sure which one is faster but if it is in high speed, I'd rather be inside a Wira than a small Kelisa.Haha! Launched time faster only xD
My kelisa k3ve2. Last before i sold it, i installed LSD inside the gearbox also. Really missed that car, it is like mini vtecwhat car did u drive bro?
Is there any problem on parts availability?My kelisa k3ve2. Last before i sold it, i installed LSD inside the gearbox also. Really missed that car, it is like mini vtec
All same like myvi. Only piston and ecu are differentIs there any problem on parts availability?
Bold on turbo not so good for the pistons. The original pistons won't last for long.bolt on turbo la ... easy can keep the manual box
Woah, your friend push the K3-VET too much already. 180hp in Myvi.I'll say if the drive is auto, then get a k3vet while if the drive is manual, a bot with cap on low boost can do. All depend on the user's preference and target. Got a friend of mine installed a k3vet on his myvi and upgraded the turbo, boosting 1.5 bar and on dyno the power output is 180whp but the turbo lag was damn annoying as the boost only start kicking in after 5k rpm on the 1st gear lol.
Agreed but for convenient and practical purposes, definitely k3vet is the engine to go. For those going to bot, better be prepared to fork out more on fuel consumption and various limitation on the boost application.waa... 5k start kicks? probably need something to do wit the turbin.. either change the exhaust housing to smaller size or change the whole turbine.. that current setup is not suitable for street. that setup is only for drag race.. but depends on the owner if he likes..
