This DIY is applicable to ALL Japanese cars as they share the same Air Con system. This is a long posting as I am covering cleaning for Washable and Not Washable Air Con Filters.
My family car Alza was just a little over 1 year old. Realized that the AirCon seems to not be blowing as strong as it was when it was new, especially on full blast.
So, I took it out and check.
Here's the compressed step of how to get to your Filter in a Perodua Alza
WOW!!! The filter is filthy!!! Just 1 year and it is filled with Dust, Dirt, Dead Bugs... and this car is always on AirCon and never have the windows wind down.
WARNING : READ THIS PART Carefully.
For most of the modern cars, AirCon filter is made out of synthetic fiber... These are WASHABLE.
Some cars comes with disposable Paper based filters (Which is usually coated with Activated Carbon), these are NOT WASHABLE. Scroll below for cleaning guide.
For Fiber type, you can just use the hose to wash off the dirt.
Here is how it looked like after washing down half of the filter.
After washing the whole filter, it looked just as new!
After that, dry under the sun until its fully dried up.
Install it back and you are DONE!
Cleaning Guide for Paper Type Filter
This one is DIY done on a Mitsubishi Lancer, which uses Paper type AirCon Filter. As you can see, the location of the AirCon filter is Exactly THE SAME.
For Paper type, you can gently tap the dust and debris away.
You can also vacuum it gently to remove stubborn dusts.
Closer look of the cleaned AirCon filter... you can see it contains activated carbon to remove bad smell from your car.
Install back the filter properly and you are...
DONE and enjoy Powerful AirCon once again..
