DIY Persona : Wet Carpet
punk
360
76
Negeri Sembilan
Normally there are 2 source of leaking from them. The rubber surrounding the door loose or damage liao OR most likely the water proof plastic sheet inside the door got holes or not seal properly.
I would suggest to dismantle the door panel and change or reseal the plastic sheet that prevent water from seeping in thru the door ala windows gaps as a first measure to check if water comes from there.
[snapback]61422428[/snapback]​
Last week found out car got wet carpet smell.
So i check around the car and found out it wet only at the center front passenger side.
I thought it get through from front engine area ( Actually it get through at the side door and slowly wet at the center area )
So unlucky, i thought only defected proton kena only because i saw many people complaining rain water get through inside the cabin area.
Search around the net, i got so many possibilities the water can get through.
So i go troubleshoot the under area, front engine are but all rubber still intact.:hmmmm:
Without thinking much, i dismantle the seats, centre console to get the carpet dry first.
  • Troubleshooting this common area first because all of the persona owners wet at this area
  • It really wet at here and speaker area also got little water get through.:hmmmm:
  • Press the black thingy to get better seal back.
  • Water get through from light green -> dark green -> then all water collected at red -> slowly drip to yellow area -> blue
  • little drip here
  • Silicon spray suitable for rubber i think ( correct me if i'm wrong )
  • Read somewhere, the solution is change the door rubber ( i dont have money now:mad:)
  • Finally got idea through one blog i read about door soundproofing few years ago :idea:( can't remember what the name)
  • Spray some silicon lubricant to help the transparent hose get in ( having difficulties here because only around 20cm hose get in only)
  • I think i need to find smaller hose to fill all around affected area
  • Water still get through but no so fast as earlier
  • The carpet already dry and it's getting dark
  • I start reassemble back everything vaccum, etc
The Ennnnnnnnnddddddddddd:burnout:
Rafale
73
7
1,508
Selangor KLIA
I had to removed my carpet once because it was wet with my cat's urine..It's a PITA to take out those center console..
adlans
138
52
I didn't use silicon instead I used talcum powder... :canabis:
cheers
adlans
138
52
TALCUM POWDER?! Those babies one? :O
Yup .. nice smell beb. Pour the powder in a plastic bag then put in the hose. Shake it all about and insert it at the rubber seal around the door.
Cheers
punk
360
76
Negeri Sembilan
Er TS, any idea about rear left back carpet?
Mine is wet in the middle of the carpet. I suspect is from the undercarriage. :bawling:
Not sure bout back carpet, mine not yet leak at the back.
Might leak from back door also, put garden hose at the door gap and have someone check from inside.
If u suspect undercarriage, go down and check the rubber seal still intact or not. ( if down there got rubber seal la, i not sure got or not :listen:)
---------- Post added at 11:26 AM ---------- 6 hour anti-bump limit - Previous post was at 11:24 AM ----------
i had to removed my carpet once because it was wet with my cat's urine..it's a pita to take out those center console..
pita?
Supra_Fanatics
20,673
3,998
pita?
PITA = Pain In The Ass
Hi fellow ZTHians,
Need some help here.
I drive the ae101 (21year old car) with stock 4afe engine. It was the family car before being passed over to me. In my hand, I bring the car for service/engine oil change every 5000km/every 3 months.
So the problem is: the engine oil level will drop till almost empty before 5000km service interval (less than 3 months). Have tried using different oil rating but still the same problem and recently realised the problem is worsening. Last time...
