Head screw broke
ddv_nk12
1,228
236
PD
My head screw broke. The one near the spark plugs. I don't know how it happened but only 1 broke. And my engine oil is leaking through the broken screw.
Is it an easy fix?
Plus, I'm now in my hometown. I am going back today. Is it ok for to drive for about 3 hours and get it done tomorrow? The leak is not that bad. Its just that there is oil coming out from the screw area.
Please advice.
Thank you.
---------- Post added at 02:13 PM ---------- 6 hour anti-bump limit - Previous post was at 02:12 PM ----------
Or is it the head valve cover screw that broke? You can see it when you open up the spark plug cover. Btw, it's a B16 head.
peterj
1,321
258
1,683
Kuching
Just one of screw tat actually used to screw valve cover...open up the cover, un tighten the broken 1 then replace a new 1
valve cover screw broke? How many are there? Take a picture la. Head screw and valve cover screw are two completely different things wor
peterj
1,321
258
1,683
Kuching
yea, get it fix 1st before you going back, the leak is going bad as you revving.... it is an easy job, i diy last time, u need is 10mm and 12 or 14mm spanner... it is bit tight to open, but make sure open gently, if it broke again at the down side, it will become big repair...and after replace new bolt, when screw tight the valve cover, dont tighten it very hard, from web, the torque is like 14-17nm only...if not, it will easy break again
---------- Post added at 01:30 AM ---------- 6 hour anti-bump limit - Previous post was at 01:27 AM ----------
make it repaired 1st, cause as u rev up, the more it will leak... diy it self since i can diy i think u can too, just need 10,12 and 14mm spanners...the bolt is tightly screwed in the head, untighten gently if not, if it broke at the down parts, it causes major repair....after tighten in new screw, install back the head cover, but tighten gently too, if not it easy break again, on the web,tightening torque is bout 14-17nm only
ddv_nk12
1,228
236
PD
I managed to drive back yesterday. I checked every a few times throughout the journey. Not much of oil leaked.
Here are the pics. It's not the head screw. My bad. Hahaha
I will be getting it done tomorrow. Is it an expensive fix? I'm not really a DIY guy. So, I will be sending to my regular guy.
simple fix..no worries.....that cam cover screw btw
ddv_nk12
1,228
236
PD
Thank you. So, roughly less than 50 bucks can settle la?
ddv_nk12
1,228
236
PD
That's good. Lol Thanks mate
peterj
1,321
258
1,683
Kuching
why not upgrade to skunk 2 low profile washer kit? hehehe.... since it come all set with the head cover screw also:love::nurse:
ddv_nk12
1,228
236
PD
Hmmnn.. something to think about!! How much is it? Need to consider. Every penny counts these days. Lol
Hi to brozz out there.
Im looking for this car. Its not stolen, i sold this car to a youngster on june 2011 n he promise me that he will make jpj inspection n transfer name, few months later i checked whether the owner do make the transfer name o not n i found out tht there is no transfer name n got summons. Road tax exp n 3 months ago my friend saw it at sunway area. Please do help me to notice the car n the owner. I cant reach him. Switch off the fon.
White color civic ek3 with...
