Replacing the alternator
Papagoines : It's possible la. Just make sure the pulley on the alternator is the same size or larger. If it's smaller it'll cause a lot of load on your engine!
Guys, I finally swapped out my old and dying 70A alternator with a new 90A alternator. The pulley on the alternator was exactly the same size so that was a bonus. Now my ICE sounds so much better! Almost completely different. Me likey! Lots of good praise for this upgrade that's for sure. Hasn't affected my cars 'feel' at all too. Seems to perform the same. Double bonus!
Blinker / ICE HU problem solved?
so far so good. As I said earlier, this issue was intermittant so I need to keep testing. But since the change everything has been working unbelievably well (electronics wise)
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
a fren of mine says, there is a place in pudu where they can mod the alternator to bigger amps using the original housing by recoiling the copper coil but i didn't ask where, btw got my tester pic.
new info, alternator mod, in pudu near the Chinese school & in jln Ipoh ol' building area coz he don't remember the shop name
Yes... recoiling, the term that I need...
I know one shop at kajang can do the same thing... just have to buy hafkat alternator as a guinea pig
As per twistedichc, it just recoil the internal... me think the pulley stay the same
It depends on the space inside. Some I see already quite pack tight inside.
Those days can just change carbon brush, nowadays got diodes....:hmmmm:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
thanks for the head's up... will ask the sifu when finally able to send the alternator
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
those days only have lights, air-cond & simple ICE only maa, nowadays so many electronically device to consider, "macam2 ada" everything got loorrr. those days u might call them alternator as dynamo for u'r bicycle, now it have to be like a generator for the whole house maa:biggrin::driver:
---------- Post added at 06:11 PM ---------- 6 hour anti-bump limit - Previous post was at 06:09 PM ----------
wehh, don't forget later tell where & costing arrr, might want 2 upgrade mine 2:biggrin::adore:
Last time my former car alternator konk, went to recon shop they only recon, no upgrade...:hmmmm:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
l2s_turbo
1,068
154
Good for you bro Izso, i had mine swapped years back from 90A to 140A. A whopping increase. Car felt lighter and smoother too.. :driver::driver::driver:
http://www.zerotohundred.com/newforums/car-problems/391787-evo-3-alternator-issue-6.html#post1063826618
l2s_turbo
1,068
154
No performance drop with such a big upgrade?
Nope, it's better in fact.. the rev is lighter due to the alternator is running ball bearing type. it's a E46 alternator.. the size is much much bigger than the original alternator... custom brackets and change belt..
Ball bearing alternator!!! I WAN!!! How on earth did you retrofit it into your Cefiro? (I assume you drive one based on your avatar..) Custom brackets?
l2s_turbo
1,068
154
It's a perdana bro.. my fren customize it for me.. he also use it for his kancil.. (he plays SPL) so need high ampere alternator.. all from BMW series..
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
kancil???? mind sharing how to contact your friend? wanna ask for alternator + custom brackets + new belts + installation into my kancil will cost me :hmmmm::hmmmm:
Source: Malaysian Digest
A driving license is considered by most as a substantial milestone in life akin to getting a credit card, buying a first home or being hired for a first job.
As Malaysians we are known for our warm behaviour and expressive nature, yet when the subject of Malaysian drivers comes to mind, one can’t help but express a considerable amount of concern on the...
