What is the stuff
Apr 21, 2013
4
Hi forumers. I need help. Does anyone know What is this stuff's name and its funtion? Have you ever seen it before? It located in my sagas engine bay but has broken tq
Looks more like added accessory then original from the car, something to do with vacuum hoses?
Yeah. Ditto VR2turbo's comments. It looks like something someone just added on. Replace it with just a normal vacuum hose.
xtorm
1,590
49
i got tht when i was driving iswara, no issues without it, with it it simply holds the distributor timing higher longer when you rev, original there is 1 which is a 1 way valve, this is both ways but with 1 more restricted then the other.
actually you save more fuels without it.
last week when i sent my car to change tires, and i also told the mechanic to clean away the dust in the drums...but recently, my handbrake was so tight where 1 or 2 clicks will prevent the car from rolling if i engage D mode..previously when i engage D mode, the car will move abit... so, when i try to remove the brake drum cover, it was so tight and eventually removal was successful, but fitting it back was super hard, the cover blocked by the brake shoe...hmm..not to mention, left drum...
