What causes brake imbalance?
jammed caliper also..
or worst...the caliper was leaking pressure....so no brake one side...thats why when brake car goes senget
last time had a jammed caliper....u will realise it when you're on 3-5 degree hill slope, your car wont roll back.
Usually won't jam immediately. Mine can feel that the car will roll to a stop faster, then you know something is wrong already. Then after a drive just touch the wheel and if one is hotter then you know that one jamming up...
Hmm.. I've never worked a twin piston before. But concept is the same. Come come let unker Izso molest your calipers.
:biggrin:
Oh wait.. That sounds so wrong.
:biggrin:
Twin same only, just got two of them.....:biggrin:
ayiaw84
17
3,003
my experience with 06 stock and new myvi(back then) has this problem, never bother much. its so damn obvious when change pads, one side wear 75%, the other 50%. it does swerve under very hard braking, but not much when doing sane speed and normal braking.
Oh Izso, my calipers are horny now... just waiting for your right time.:call:
As usual, going XXX already.....:rofl:
---------- Post added at 09:35 AM ---------- 6 hour anti-bump limit - Previous post was at 09:33 AM ----------
Because Myvi is for normal use and to be driven at sane speed.....kakakakaka:rofl:
Should check the brakes, could be binding on one side....:hmmmm:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Please define "sane speed"? :hmmmm:
:biggrin:
this murnin as usual on my way to work and usual path then wat was im thinking miss judge at the corner zrappppppppp!!! my 4 month old rim scratched....the lip part pretty bad, so there any way i can send to repair??
