my ae101 problem
deng3882
132
klang
need members and sifus help here,
Im driving ae101 with 4age blacktop Auto..i recently just change my car front lower arm bush to ori toyota..after few days of driving..my car start to have this "krock krock krock" sound when i drive on rough surface road..before changing have this sound too but very light sound only..after installing new bush the sound become louder..then i went to check again and was told my stabilizer link bush pecah d so i replaced it with 555 brand stabilizer link..and again got this sound after few days of driving..can anyone tell me whats wrong with it.??.or any other things that will cause to have this sound.??.
Im using Tein adjustable so any problem related to the adjustable.??.worst part is my car handling now keeps understeer..handling is bad after having the sound..:banghead:
grrr
66
1,508
SELANGOR/KL
Inspect the stock mounting bearing. Broken bearing also produce that kind of sound.
FGT
529
31
which mounting bearing you refering.??.sorry newbie here..
I had this problem before after changing the bushes and it turns out a couple of screws were loose. The car should handle like new (well, almost) if you had change all those bushes.
I think brand 555 is a decent brand. My previous car, an LE had 555 all over it and it served me well.
Where are you from bro? Uncle hong from Sunshine would able to identify the cause and fix it for you if he can. If something is faulty he will probably ask your mech to replace them as he only specialises in tyres and alignment. He will tell you what to change.
Coordinates are here: 3.081005,101.646189 off Jalan Kelang Lama, Batu 7, PJ.
ayathu
116
18
deng3882,
My advice to you, please do the alignment at shop that does not use electronic alignment machine, go for the shop that use mechanical equipment . This my experience.
deng3882
132
klang
i first oso some screw did not screw probably so i went back to the shop and they screw everything again but still have this sound..im from klang..thanks for the information..i will go there when im free..
---------- Post added at 04:54 PM ---------- 6 hour anti-bump limit - Previous post was at 04:53 PM ----------
deng3882,
oh it is.??.unproper alightment adjustment will cause this problem too.??.
nappx
2,532
185
5,163
kLaNG-kEy_tEE
from klang...yumcha larr..near ICT there...then can hear the thing..can bring you to i aligment shop and check for you...if you want lah..
deng3882
132
klang
haha..so friendly member..you think is cause by unproper alignment too.??.
nappx
2,532
185
5,163
kLaNG-kEy_tEE
i not say unproper aligment...i not machenic...just try to help for those ask....or you can go yourself near ICT there got one mamak call ABIZ MAJU, same row got one aligment shop, (not continantal shop) ask ASENG he might be can help to identify...then up to you...
you ask..i tell..not mean so friendly...bro..nothing hidden hidden...
deng3882
132
klang
alright..thanks bro..i will go ask when im free..thanks for the recommendation..
hallo, i experience problems wif my volt meter..im driving an Auto transmission car..When i start the car, gear in P position, the meer will show voltage ard 11..but when i put gear in D or R position, the meter will drop all the way down t 8. how come eh? must change battery ??
