Mythbuster/Does-it-work? Spark plug cables
dennisdreams
333
21
diff spark plug had diff char which need diff tuning, cannot really saying the cable was doing all the works but it's the setting also took a lot of measurement as well~
just my 2-cents~ cheerio~
drjoe
Mar 19, 2012
Johor Bahru
I agree with you, proper choice of the spark plug type (e.g. hot type / cold type, spark plug tip gap, and etc) is important to optimise the engine performance, the function of the spark plug cable is just to conduct the high voltage current from the ignition coil to the spark plug. Spark plug cable has stronger ignition spark energy that enable to have the self cleaning of the carbon deposits from the spark plug, especially when the vehicle is running at a speed of exceeding 80 Km/Hr, that can reduce the carbon fouling of the spark plug avoiding the misfire problem.
cvkit17
2,884
1,354
I've got something in my mind. What does the ECU adapt to, when we have a bigger spark? The controllable parameter to the ECU is fuel. When less air going into the chamber, the ECU adjust accordingly to it. But when we have a bigger spark or misfire, as far as I understand, the ECU does nothing to counter it as it has not control over them other than providing signal to give electricity at the right time. Unless I am wrong. Any bro can clarify?
D7zul
2,697
848
Shah Alam
IMHO, ECU control fuel & spark timing
It detects air by AFM, MAP, etc & inject fuel according to the programmed air fuel ratio
And it checks with knock sensor & oxygen sensor
Then it adjust the fuel & spark timing accordingly
VTEC, VVT, etc has another set of programming n sensors
This is from my knowledge la. I could be wrong :biggrin:
---------- Post added at 01:19 PM ---------- 6 hour anti-bump limit - Previous post was at 12:54 PM ----------
ECU didn't detect a bigger spark. It just detect knock & oxygen
If it detect knock, it will inject more fuel & retard spark timing
If it detect less oxygen, it will inject lesser fuel & advance spark timing
In the case of bigger spark, the oxygen has been burn completely..
So, ECU will reduce the fuel & u'll get better FC :biggrin:
I stand corrected :biggrin:
cvkit17
2,884
1,354
I agree that spark timing is to avoid knocks..I get the theory of bigger spark results in better combustion i.e. a more complete burning. But I personally do not think that it affect or being effected by AF ratio. Of course, with bigger spark, better combustion, thus more power and smoother ride. I think it actually improve the burning efficiency instead of providing more fuel/air.
I believe that a good ignition cable can improve the car responsiveness and "smoothness" we called...berapa RM sebiji btw?
achelone
125
27
when the burning is complete, how more complete can it be? if your ignition is weaken then replacing worn part will get the original performance back....but it will never obtain more than original....this excludes tuning topics and etc.....that another story...
Veloc
3,234
991
Sabah
Agree with this. Besides burning more completely and the ECU injecting less fuel, the increase response and torque will also result in less throttle input giving better FC.
InitialD
1,299
93
Anymore reviews? Any update on the dyno chart?
Anybody else using this Best I Cable?
How much is a set (4 cables)?
GEFORCEXTREME
151
13
You believed yourself that a stronger spark leads to more complete burning. Complete burning on the other hand means AFR is affected. So ECU read sensor readings, and adjusts according to the tune and adjust its output potentially leading to better performance.
When,use R,P,2,3 all are working well,but when i use D/4 for driving ..not speed more than 60 k/mh.Its work fine.But,when im speeding more than 80 km/h .. after use brake and stop the car at traffic light.
The car not shift the gear ,sometimes its stuck at 1st gear some time it became to Neutral,even im not change the gear to D/4 to N.If,i still push the gas pedal,the blinking comes on ,i need to restart my car back.After,that everything becames to normal.
If,i still use D/4 and...
