Nice work! I bet that this coating is harder, thicker and more durable than all the other coatings (Opti coat, sol-gel, glass coat, etc) that people put on headlights. Do track the durability and how it fares over a period of time.
No need, that's the beauty of it. It's supposed to fill in the sanding marks as it will self-level and cure.
But I should've followed up with 1500 grit because if look closely still can see the 1200 grit marks, that is if you look as close as 10cm away. Other than that, quite satisfied with this, but not cheap, costs SGD 95 which can do 10 sets of headlights.
i have a problem with my car.. the steering vibrates excessively from about 90km/h onwards.. i have changed new tires.. rims checked not bent, alignment and balancing done.. what else could be the cause of this? btw after doing alignment and camber alignment the vibration got stronger.. my car set up is 4agze custom made driveshaft on the left side to correct length but same spec as ori gze shaft.. right side is original gze drive shaft. bearings are relatively new.. hope someone...
