- Apr 11, 2006
- 203
- 0
- 5,016
hey bro.. i drive a DB8 too..
dont simply install Rear anti roll bar from Type R .. must replace the subframe like ASR..
else ur chasis koyak.. as for the front, no problem.
as for upgrading the bushes/rubbers.. i highly recommend it.. i'm using HardRace..
all 22 pcs for the suspension, chasis, excluding engine mounts.
> it corrected my rear Positive chamber.. (replaced the trailing arm bush), and increased the ride height (17" rims 215/45 tyre rubbing the fender wall) little bit.. etc.
as for UR bars.. i ordered all! (except fender bars coz of custom skirt touching the fender).. only able to install 4 point in rear trunk (required 2 drill n bolt - left n right to the bottom, and 2 bolt on straight on the absorbers), and rear lower strut bar.
as for the front, the 3 Point bar cant fit as it was obstructed by the firewall. WTF??
Front lower cant fit as the holes on it was 1 cm shorter..
check your inbox for details on FB - integra dc2/db8 club - Teggerz
