Safe and effective waatermark removal on glass!
eohl79
293
164
543
Safe and effective watermark removal on glass!
Happy New Year BTW everyone!
Waterspot/mark is a very common problem. Most cars are constantly being subjected to the daily harshness of acid rain, contaminants in the air, hard water, etc and left off drying in the blazing sun. The severity of water spot/mark usually depends on how well the surface of the paint/glass is being protected. A severe waterspot/mark usually stems from residue/chemicals in the water droplets/streaks reacting with the surface (paint/glass/plastic/rubber) and leaving a very unsightly mark.
This article that I am posting here has nothing to do with paint correction but treating the effects on glass instead. My daily driver, my K-car, has been under constant abuse day in and out and left in the open 24/7. With little or no protection except a weekly car wash for the past 9-years, one can expect all sort of problems. This is also my guinea pig on my journey venturing into the wonderful world of detailing. Watermarks is present on all windows. Some windows more severe, some less. The thing that bugs me the most is when driving in the morning or heavy rain. The waterspots/marks causes poor visibility. Even the effectiveness of the wipe blade is reduced. The window on the driver and passenger side is blurred and thus causing problems when trying to view the side mirrors.
Ok, less talk and more action. I am going to depict the watermark problem, corrective action and subsequent protection to the glass surface in the following pictures with description for one of my car windows. The sequence of correction to remove the watermark starts from the least aggressive method first as the severity of the watermark is unknown.
First of all, let's take a look at the test subject. A window that has been left unwashed for a day.
Figure 1: Test subject, unwashed window
Not too bad or dirty. However, there are still minute particles and dirt which I will clean up quickly with my regular combo:
1. Optimum no-rinse wash aka ONR
2. Cheap wooly MF for ONRing the glass
3. Osren white chamois for drying off the glass
4. Osren premium microfiber towel to buff dry and residual water and pick up any lint left behind
Figure 2: ONR kit
Here is a pic after cleaning the glass with ONR. You can clearly see watermarks/spots all over the glass. ONR stands no chance in removing the watermarks.
Figure 3: After ONR wash, watermarks still visible
Next, I use the following:
1. Optimum no-rinse clay lube ratio
2. Soft-99 detailing clay
Figure 4: Clay and clay lube to see if it does any good to the watermarks
After claying, the glass did feel smoother with the clay picking up some embedded surface contaminants. However watermarks are still visible.
Figure 5: After ONR wash, watermarks still visible
Next up in my arsenal, OPC 1:3 diluted ratio
Figure 6: OPC 1:3 diluted
After using OPC 1:3, there are some visible contaminants picked up by observing the MF cloth. It is not a solution to the water streaks. But lets inspect for watermark/spot on a dry surface.
Figure 7: After washing off OPC 1:3, water streaks clearly visible. This bothers me the most.
After drying... watermarks/spots still there. Already done several OPC 1:3 cleaning and wipe downs but to no avail. Guess the water marks is already etched in.
Figure 8: Water marks still visible after OPC 1:3 cleaning
Now, from reading forums and asking people around, there is usually two solutions which people would recommend:
1. Acid based cleaner - Good in removing watermark/spot but never use it on a scratched glass or wiper area - the acid may seep in through the crevices and cause more problems. Might cause hazing to the glass. Might eat or damage paintwork/plastic/rubber, etc if not handled with care. Dangerous to skin. Need to keep running water at bay to wash off ASAP after use. Handle with great care!!!!!
2. Glass polishing - Polishing is by means of using abrasives to remove a thin layer off the surface in order to remove imperfection. Problem here glass is a very hard material. The front car windscreen is usually laminated glass and made up of softer glass. All the rest is usually tempered glass which is way harder. Based on my experience, the regular paint compounds with the harshest rotary pads seems like using very fine polish on glass - not much correction. You would need rocks or diamonds to really give glass any cut. There are special glass polish/compounds which contains Cerium Oxide but is a little hard for me to obtain at the moment. There are also other tools and abrasives out there that designed for polishing glass.
Knowing the options available to me from above, I chose #2. The acid based cleaners are simply too dangerous to my linking and the outcome is a bit unpredictable. So I went to Osren to find out more on what they have in store to help me solve my watermark problems. The safest prescribed remedy:
1. Osren abrasive powder based watermark remover
2. 3M microfine sanding pads
Figure 9: Osren abrasive powder based watermark remover and 3M microfine sanding pads to the rescue
Osren abrasive watermark remover is pretty simple and safe to use. All you needed to do is mist the glass surface work area, spread some abrasive powder on a damp sanding pad and work on the area. Not too wet and not too dry. If the pad do get dry after working on the surface for a period of time, spray some water not on the glass but on the back of the pad to get going. This prevents the sanding slurry from running all over the place. One tip is to cling wrap the metal panels underneath the glass to prevent marring the paintwork and the messy clean up process. Work on horizontal lines, then vertical lines to ensure even and edge-to-edge coverage. Wash down properly once you think you are done!
Figure 10: Sanding slurry
After using the abrasives, be sure to do a proper clean down on the glass and all other panels underneath the window. You really don't want the harsh abrasives to mar the paint work!
Figure 11: Check out the zero water beading on the glass surface after sanding down with the abrasives! Notice the water tension surrounding my finger!
Figure 12: After removing my finger...
Figure 13: After a quick wipedown with ONR, Tadaaaaa! Water beads return!
Figure 14: Water spots/marks gone!
After the sanding process, there is almost no watermark/spots to be found! Glass appears clearer and very very smooth - better than after claying. What is left behind is the scratches and pits on the glass. I've done on a test spot, no matter what pressure or amount of abrasives used, it is almost impossible to level out scratches and pits on the glass. For that, you would need some real glass cutting compound.
I did notice that the scratches/pits is visible with a strong white LED back light. If possible shine along the edge of the glass.
Figure 15: Notice the pits on the glass highlighted by the LED backlight?
And lastly, the final protection with Opti-seal and the short nap side of Osren's premium MF towel.
Figure 16: Opti-seal for protection
Thanks for viewing.
Disclaimer:
- I've tested only on tempered glass on my car. Don't know if the abrasives would cause scratches on laminated glass.
- This is a DIY project. Always do a test spot first.
- Don't blame me if something bad happens! Share what you know.
- No I'm not selling any of the products or providing any services! Don't ask me for price!
Figure 17: Tested on temperlite glass. Oh, yeah it is Jan 01, 2012. Buckle up on the rear!!!
All feedback appreciated!
Veloc
3,234
991
Sabah
Thank you!!! Watermarks on glass has always been a tough thing to remove... Now we know what product to use...
s1tl
1,237
1,019
Ipoh/KL
but i heard sanding ur windows will cause micromarrings...my bmw e36 windscreen had the same treatment by the previous owner. no watermarks but full of micro marrings which glares at night.
If you could, can u snap a photo inside the car with the street light shinining through? im curious of the results. if no marring i can consider using this edi =D
eohl79
293
164
543
Thanks bro. One thing though, have not tried it on laminated windscreen. Will do so when I have time. Appreciate any feedback, concerns. The watermarks seems to bother me more than the undetailed paintwork though on my beat up car...
Hi bro Josh, think need to know how previous owner sanded his windscreen - what kind of sandpaper, etc. If it is the front windscreen, the glass is softer and can mar easily because of laminated glass. This method that I am posting here uses the 3M microfine sanding pad which holds water and is slightly abrasive (higher than 1000 grit). The abrasive gives the extra edge of polishing the glass. By spraying less or more water and controlling the amount of pad pressure, the abrasiveness can be varied. I have not tried it yet on front car windscreen yet or laminated glass. Will post pics of the night shot when I have time today or tomorrow. Not sure it will work for all car glass though.
---------- Post added at 08:28 AM ---------- 6 hour anti-bump limit - Previous post was at 08:25 AM ----------
This is what I meant by shining a high powered LED torch light along the edge of the glass. You can see all the defects including those within the glass. Did not see it with the halogen light straight on.
pangyau
1,153
302
1,683
Malaysia
nicely done...!!!
Kindly advice where to get 3M microfine sanding pads?
Veloc, maybe you could help me... using to restore my lamps..
Veloc
3,234
991
Sabah
nicely done...!!!
I've been waiting for you man! Haha. Anyways, Lamps don't need those. Just sanding and polish.
eohl79
293
164
543
nicely done...!!!
Thanks. Can get everything from Osren. Problem using the pad compared to sand paper is you are missing a backing pad for even sanding especially on softer material. Follow Veloc's advise. Good for sanding curved area though.
Dude, nice shirt.
ha... Old rag shirt wor...
Wow this is something else. I want to do something about the bleedin' watermarks on my front windscreen. When you find some sort of product that does the trick let me know!
eohl79
293
164
543
Bro Josh, results as requested. Here are my findings. Night shot with street lighting - reflective and transmissive light source. Using my Sony NEX C3 camera with pancake lens on twilight mode and ISO6400. No sanding marks or marring visible. Just pits/scratches and defects within glass. No watermarks.
Figure 19: Reflected light source. ISO-6400, twilight mode.
Figure 20: Transmissive light source. ISO-6400, twilight mode.
---------- Post added at 11:50 PM ---------- 6 hour anti-bump limit - Previous post was at 11:45 PM ----------
Bro Izso, do you have a picture of the bleeding watermark? I am still a little reserved about correcting laminated front windscreen glass. Need to do some reading up and some experimentation - don't want to hack through, spread false info and cause misery. Heard that some glass can be harder, some softer. So not sure about final outcome yet. Will keep everyone updated when I have time...
Nice.. if you figure something out do share! I'd like to post it up as a feature since a lot of people have this issue!
(Btw, my "bleedin" was a figure of speech. Like saying "bloody windscreen". Hehe)
jy_1990
25
I'm having this problem too.. thanks for sharing the info... can i know where to get osren products? and also the other products used here..
eohl79
293
164
543
Search for Osren Malaysia. Their main office is in KL. They carry a lot of detailing stuff there. Call them up. Optimum stuff you need to search the forum for the sifus and PM them. Do a search for "Detailien".
arrowhead
4,621
152
5,163
Damansara/PJ
wow. that is just awesome. my front windshield would definitely need watermark removal...
kc2
1,354
1,410
thedetailers.blogspot.com
great effort
and thanks for your precious time sharing with us, by all means avoid acid, F....H.... asked those who has done that....avoid R...x too....amonia & killing all yr wiper blades
it is safe when u dot it slowly & make sure u have plenty of water as lube
as for front windscreen - I have reservation
OOS it is has been best for all exterior - once every 3 months for all exterior ....that bottle will last u for 10 years protection
as for front windscreen - monthly application will be great
Thank you for sharing
hey there..sorry for posting this topic..but i've searched other thread relating to converting waja auto to manual,none give me the best answers..:banghead::banghead::banghead:so here i am,seeking for your advice..:adore::adore:
1.how much does it take for converting the transmission(complete conversion with complete gearbox set) plus installation)
2.if i ever get to convert from auto to manual,do i have to retune the engine or the ECU?
3.will there be any complications or problems...
